Question about Samsung RS2630WW Side by Side Refrigerator
I defrosted the freezer and now there is a light blinking on the front panel. what do I need to do to get it running again
I replaced the covers over the coil that is inside the freezer and once the i plugged the sensor back in every thing worked.
Posted on Dec 14, 2009
    President:
  • 1,891 Answers
Probably change filter and cancel light . instructions for your model . holding 2 buttons on control for 3 sec should stop light. finding the correct ons is the trick .. there may be info on or in the ref . a tec sheet is sometimes behind the grill at the toe . whirl / maytag / ect . some models of maytag are samsungs . if some of these don't work get back with me . we'll look a little harder ..mm
Posted on Dec 12, 2009
Model GS20-D side by side will not cycle. Why?
Hello Carol;
My name is Peter. I am a retired field service technician.
Your given model number has more digits to it, therefore I can not identify your particular unit for spare parts numbers.
1.) Defrost Timer - Remove the front bottom grill. It just clips on, 1 clip on each end - just pull on it. On the bottom right you will see a small plate with a hole through it. This hole has a slot for a screw driver. With a flat head screw driver turn the slot clockwise. You will hear a clicking sound. Slowly turn one click at a time until the refrigerator turns off.
Wait 30 minutes. Observe the freezer back wall. Do you hear a hissing sound (condensate hitting the heater) or is the back defrosting? If this is happening then you have a bad defrost timer.
If this is not happening your defrost timer is good. Using your screw driver turn the slot 1 click at a time until you refrigerator turns on.
2.) Defrost Heater - Purchase this part before you start the work. Observe the part and the connectors on it. Unplug the unit. Completely empty your freezer section and all shelf. Remove the light bulb cover, it clips on squeeze to remove. Remove the light bulb. Unscrew all of the screws in the back panel. This panel has rubber strips on each side and may give you some difficulty removing the back panel. Observe how the heater is mounted. There are two reflector plate holding each heating element, remove them, 1 screw on each side. Disconnect the existing heater and install the new heater. BE CAREFUL THE FREEZER COIL IS RASOR SHARP, WEAR GLOVES. Reassemble. I do not think you will have to remove the ice maker and bucket, but you may, to remove the lower back panel.
Purchase Locally: Defrost Timer $63.00. Defrost Heater $65.00.
Purchase over the internet for about 1/2 price.
Oct 29, 2014 | Magic Chef Refrigerators
Blinking Fridge Light and Both Fridge & Freezer Warming Up
I would say to contact Servall, a component source for all appliance repairs. They have a Web site and are helpful. You should also try the Web for any repair Manuals for your unit.
There are timers for the Defrost cycle. I am familiar with the old mechanical type, the blinking of the computer type is often in a Code which diagnoses the problem. You need the Manual to translate what the blinks mean.
Jul 10, 2014 | Samsung Refrigerators
My Hotpoint Fridge Freezer 187P has Blinking Lights
Kindly upload pictures of the two lights flashing. What does the writing next to the two lights read?
Dec 06, 2017 | Refrigerators
Freezer light blinking Ice maker not making ice freezer not as cold
sounds like ur freezer is in alarm due to not being cold enough and wont allow the ice maker to distribute water to be frozen into ice u should have a fan behind the back panel inside the freezer make sure it is working and the coil underneath it is not frozen solid if the fan isnt working then check and make sure it has power if it does and the fans not running then replace the fan and this should get ur freezer working again but if the coil is frozen and the fan is running then u may have a bad defrost element that runs through the coil it is black u can test it by taking the wires off it and checking continuity thru it if it has continuity then its ok if not then it needs replacing
Mar 01, 2010 | Samsung RS2534 Side by Side Refrigerator
My freezer is working but the refrigerator is not cool at all. we had a black out and it came back on then the lights went out again. since then the refrigerator is not cooling. Thank you
Good day,
If the fresh food section was O.K. then after the power failed off and on, the first thing to check is the fan motor in the freezer section. It was probably burned out. Open the freezer compartment when the machine is running, you should hear the fan running, if not, remove the back panel, and check the motor, and replace if needed.
If the fan motor is running, remove the rear panel and look for ice/frost buildup on freezer coil.
If Iced, then the defrost system has failed.
The defrost system is made up of 3 parts. The main heater, mounted across the bottom of the coil, the defrost thermostat, a small 1'' round disk mounted to the top of the coil.
Both can be tested with an ohm meter, but must be done before the coil reaches 32 degrees, or the test won't work. Both should read zero ohms
Lastly the timer or adaptive defrost control, mounted in the fresh food compartment.
Below is an excellant tutorial on defrost systems.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Not cold in the fridge part top freezer seem ok.
Good day,
One of 2 problems.
1. The fan motor in the freezer compartment is not running. While the machine is running, open the freezer door. You should hear the fan motor running.
If not, then remove the rear panel in the freezer section, and inspect and replace the motor if needed.
2. The defrost system failed.
When opening the freezer door, look at the rear panel. If you see the beginning of a frost build up on the panel, the defrost system has failed.
The defrost system is made up of 3 parts. The main heater, which is located behind the rear panel in the freezer panel.
The defrost thermostat which is a small round device clipped to the top of the evaporator coil, and once again, is located behind the rear freezer panel.
The timer, which is located in the fresh food compartment on the top underneath and behind control panel.
You will need an ohm meter to test the main heater for continuity, and the defrost thermostat as well.
The timer can be checked by using a small screw driver and turning the advance shaft clockwise until the machine shuts off.
Wait 35 minutes. If the machine turns itself back on, the timer is good. If not, it is bad, and needs replaced.
Here is an excellent tutorial to explain the system.
Dec 07, 2009 | Kenmore Refrigerators
BLINKING dE(DEFROST) LIGHT ON OUTSIDE DOOR PANEL OF GE TFX27FH.
look for the manual its usually underneath...remove the grille and look inside. sometimes its taped up
i can help you troubleshoot if you find!
Oct 08, 2009 | Freezers
Food thawed, freezer running. I moved packages from in front of air ways and turned thermostat to coldest setting & it didn't change anything, freezer still at 32-33 degrees. help
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Freezers
GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Oct 20, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Freezer defrost all. RS2556
The most likely is that the door was not closed properly, this is very common on this model, what happens is that the door closes against the freezer contens and therefore appears closed, this allows warm air into the unit which starts to melt the ice, if this should happen again it is a good idea to completely defrost overnight with the doors open and then re start the next morning as ice often builds up behind the rear panel. Regards Advisor
Jul 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
141 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
