Question about HP L1740 17" LCD Monitor
Monitor test mode turn off:Press Menu and +
How can i get my nokia c2-01 from test mode?
To exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
Jul 25, 2018 | Nokia Computers & Internet
Tip
AOC monitor Lock-Unlock instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
on Apr 25, 2010 | Computers & Internet
Osd Lock how to open?
http://s807.photobucket.com/home/budm/allalbums
Jun 14, 2011 | AOC 917Sw 19" LCD Monitor
My optiquest Q19wb monitor has the contrast/brightness option disabled in the menu..I am using it as my secondary monitor..OS used is win7
Try unlocking it:
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
Apr 16, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
I dialed ##8378<SEND>, then clicked
Typing ##8378 Send brings up the phone test screen. When you select #2 (Field Test) and then select OEM monitor and select "enable" the phone resets and enters test mode.
In test mode you can press the volume up button to bring up the test menu. You can navigate this menu using the 1 and 3 keys on the number pad.
The most notable screen in test mode is found by pressing 3 until you reach SHDR protocol monitor will bring up the screen that displays real time reception and transmission information.
Other screens display other system information, but I caution against "playing around" with these menus too much.
To temporarily hide the test mode screen you can press the volume keys again. To take the phone out of test mode completely follow these steps:
1. dial ##test or ##8378 and press send 2. select 2 (field test) 3. scroll down to and select 10 (OEM monitor) 4. scroll down and select Monitor DISABLE 5. the phone will reset and return to normal mode.
Feb 13, 2011 | Casio G''zOne Type S Cellular Phone
I have got nokia 1208 cellular phone and that phone is showing test mode how to solve that problem its very urgent.
Hi, to exit test mode, turn off phone.
Feb 02, 2011 | Nokia 1208 Cellular Phone
AOC LCD MONITER OSD LOCK
Apr 24, 2010 | AOC 917Sw 19" LCD Monitor
My nokia 1208 is stuck in test mode
Sep 03, 2009 | Nokia 1100
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
Displays test mode
Jul 03, 2008 | Cell Phones
HP L1740 17" LCD Monitor Logo
1,171 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
