Question about Sony Cyber-Shot DSC-F717 Digital Camera
No image on LCD while all else seems normal.
Everything appears to be responding normally except that I see no image on the LCD or the electronic viewfinder. The Sony splash screen does show up a power on. The various settings do show on the screen, but the background is black. There is no lens cap on. When I switch to review mode, the LCD briefly lights up in blue, then goes black. When I press the shutter, the LCD show the recording progress bar, but no image. The Nightshot/Nightframing settings are off. I have a new battery newly charged which shows 22i minutes on the LCD. Any suggestions? Many thanks.
    Problem Solver:
  • 13 Answers
Go here:
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCF717&news_id=161
Sony had a certain issue with the CCD chip on this camera. If it's this issue, they'll fix it free plus $20 until March 2010.
Posted on Dec 25, 2009
SOURCE:
Samsung LCD TV Problem with Video
If this is a LCD, you have a failing LCD panel. Typical of older Samsung sets!
Jun 10, 2013 | Samsung Televison & Video
Dell 1503FP works, but won't start up again for a few hours
Hello there.
Seems like electronics pack up but try an old one. disconnect all the data cables from your monitor side(HDMI, DisplayPort, VGA, USB etc.) or computer side if the ones on display are built-in. Leave only the power cable. Unplug the monitor`s power cable. Press the POWER button on the front of the display and keep it pressed for 45 secs. Plug everything back and give it a try.
Good luck.
Jan 18, 2018 | Dell 1503FP 15" LCD Monitor
Duplicate image in pink displays on the screen.
From your description, it sounds like an alignment problem. There are 3 LCD panels in the projector. Each one displays an exact duplicate image of the others except it's either red, green, or blue. Under normal conditions, the images precisely overlay one another so you get a sharp image. Due to age, heat, or vibration/shock(impact) it would appear that the red LCD panel has shifted a little, giving the "ghosting" effect. You'll have to have the unit repaired by a qualified tech. He'll have the special electronic equipment needed to align the panels properly. Before sending the unit in, try a reset in the menu. Sometimes, the projectors can shift the image electronically, using math algorithms which will try to auto-sharpen the display. Hope I was able to help!---Rick
Aug 11, 2009 | Sanyo PLC XU35 Multimedia Projector
Vizio 42" LCD with Screen problem
Find the LCD Controller board (TCON). Disconnect the cables from it to the LCD panel. Carefully re-connect them. Make sure the cable is properly positioned in the connector. You may have to do this several times to get it work. The flat cables are a problem.
Feb 23, 2009 | Vizio GV42L 42 in. LCD Television
Lcd screen on sony dsc f707 is green
After much money at repair shop for green viewfinder,
3 minutes ago I rapped my F-707 sharply on the
camera bottom, and green disappeared. Everything
else appears to be normal now.
Jan 05, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
Digital camera LCD monitor not working properlly
You might try pushing the DISP button with the unit in camera mode with the LCD open.
Dec 22, 2008 | Cameras
NO IMAGE
Check the card isn't set to write protect mode with the switch on it.
I will assume the picture is viewable through the LCD and everything else appears to be normal.
Apr 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon A520 Everything works, except the button you take pictures with. It wont work.
I need more information about what symptoms you are experiencing. I am going to guess that your shutter is stuck closed. This would cause a blank image to show on the view screen and your captured pictures. The regular icons and text would still display normally. Is this what you are seeing? If not please explain further what is happening and I will respond again with more information. David Millier Advance Camera Repair
Mar 12, 2007 | Canon PowerShot A520 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
680 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
