Question about ASUS WL-500W Router (WL500W)
Peer not responding error message
I've been getting this error message (Peer not responding) from the internet connection status page on my Asus WL-500w router. Is there a solution to this problem. Much help is greatly appreciated. I have this router connected using a DSL Siemens speedstream modem 4100 model.
osborne382
  • 306 Answers
SOURCE: ASUS WL-520g wireless router and hutchison broadband connection problem
You need to contact your ISP if the internet connection is not there....
Posted on Nov 10, 2007
SOURCE: ASUS WL-500W not connected to the internet
how your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
Posted on Mar 28, 2008
shaggyrat
  • 1224 Answers
SOURCE: Intermittent WiFi with ASUS WL-500W
someone has tapped your wifi call your local service provider they bring out a device that searchs those hidden theives that are stealing your signal for right now i would disconnect wifi and go straight ethernet or usb till service providers tech comes out once you down your signal pull the plug for a day they should let off
and if you still want to use your internet pull only the router plug out of wall for at least 25 seconds and plug back in this resets router so connection can come back up and establish
Posted on May 17, 2008
  • 67 Answers
SOURCE: Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Posted on Dec 10, 2008
I had the same problem. The problem is interferance from other devices. Solution, Change the channel from auto to a fixed one. That worked for me. No more droped connections, and a very strong signal now.
Posted on Jun 23, 2009
When accessing the internet on tablet the `Unfortunately, internet has stopped` message appears even though it is showing that wifi is connected
Verify that your router has a good internet connection and that its local IP service (usually through DHCP) is running. Try entering the router's TCP/IP address (e. g., http://169.168.1.1) in your browser's address bar to see if you can get the router's status page.
One of the more common failures in older routers is IP service dropout, particularly if the router overheats because something was stacked on top of it. This will result in client error messages such as the one you describe.
Another possibility is an authentication failure, but that would generally mean somebody messed with the wireless network access password, or there's a bug in the wireless coding (as in some ASUS laptops - this was fixed in a firmware update).
May 28, 2016 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
Facebook page comes on but message at bottom says facebook not responding and nothing happens.
It may be your internet connection, try to close the page and going into your browser settings and clear cache and history, etc. If it still happens check your router for security status. If your confuse let me know, I would have needed more details than the ones presented!
Mar 27, 2015 | HP Compaq 6710b Notebook
Software to restric internet access
You can use a Bandwidth limiting software on the appropriate laptop that can set an Upload and Download speed limit on any Internet accessing software: it is a fair-priced commercial s/w called 'Netlimiter' and you can download the 'PRO' version on a 28-Days evaluation from: http://www.netlimiter.com/download.php
Very handy to limit each application bandwidth especially Data transfer from your Laptop when using a browser (such as IE/Firefox/Chrome) at the same time as a Peer to Peer application (such as Azarus/Edonkey/EMule).
Dec 20, 2009 | Computers & Internet
I can't get my at&t mail from my laptop
check whether which connection is activated..i think the wireless connection is wrongly setup .. if u disconnect from your fathers computer ur internet will work ... so to overcome this problem.. go to internet options in your browser and go to connections--> advanced LAN settings..in that mention which network adapter is used for internet .. then the problem will be solved
Jun 19, 2009 | Yahoo Mail
Error message server is not responding
Server is busy, or the time to have page load has elapsed. Try to refresh it. Or try another web browser.
It also appears when your offline or no signal from the isp.
Apr 08, 2009 | Microsoft Internet Explorer 8
Dialup 56k modem not responding.help says harware failure
whts the name of the modem and the light status and , whts the error message u get when u try to connect to the internet
Nov 15, 2008 | Compaq 56K Modem
Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Nov 12, 2008 | ASUS WL-530g Router
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Open Questions:
ASUS WL-500W Router (WL500W) Logo
322 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
