Question about Delta SA350K Shopmaster Boss 1/4 Horsepower 1,724 Rpm Benchtop Spindle Sander With Complete Spindle Sander Set
How do i change the spindle , how do i loosen the bolt
I used an impact tool, loosened in seconds
Posted on Dec 13, 2009
2 Suggested Answers
Editor925
  • 285 Answers
SOURCE: On the Bench Oscillating Spindle Sander how do you
Remove the spindle from the machine itself before you change the sanding sleeve. There should be a flat section on the bottom of each spindle that you can hook a wrench on to hold it while you undo the top bolt.
Posted on Mar 10, 2009
Remove front wheel
remove the disk calipers. loosen the bolt at the bottom of each fork. remove the spindle nut and drive the spindle out with a soft mallet. keep an eye on any spacers or dust seals as to where they are located.
May 28, 2014 | 2008 BMW K 1200 S
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
How to loosen a bathroom tap spindle to change the washer?
How To Remove Bathtub Faucet Stems
Yes, faucet stems can be very difficult to loosen after years of mineral buildup. First you want to make sure the valve is open half way. Spray the stem nut with a lubricant such as WD 40 or the like.Let the lubricant work its way inside the threads. You may also use a heat gun or hair dryer to heat up the nut a little. Keep trying to loosen the stem ( a stem socket should be used). Keep spraying the stem nut. Try to go the other way, to tighten the stem, but do this on the gentle side. Do not put much pressure on the turn. It's a matter of a little at a time, as with a frozen nut on a bolt. Good Luck!!!
May 19, 2014 | Home
Hub bearings fell out of spindle hub and the bearing case melted to the hub houseing
Is there a pinch bolt holding the strut to the spindle? Loosen it and drive the spindle off the strut.
Nov 11, 2012 | 1997 Ford Windstar
Right front lower contro arm replacement. 1990 Chevy Lumia Euro
Beat on the spindle that holds lower control to the lower spindle while prying the lower control arm down this will loosen the lower ball joint spindle. If there is a lock bolt take it out. Grind the rivets off in the lower ball joint. The new one comes with bolts to replace it (not rivets)
Sep 10, 2011 | Chevrolet Lumina Cars & Trucks
I need to know how to change the blade to my Milwaukee heavy duty abrasive cutoff machine.
Look around the housing where the switch handle bolts on. You should see a spindle lock pin. With the unit unplugged you want to push in the pin and when you go to tighten or loosen the blade bolt the spindle will lock into place. Sometimes you need to turn the spindle a bit for the lock to catch. Once you have changed the blade just release the pin as it is spring loaded.
Jul 13, 2011 | Milwaukee 6180-20 14" Chop Saw Abrasive...
Trying to remove castle bolt to change knuckle and spindle. having a lot of trouble
Use a good quality wrench, Add a pipe to lengthen the tourqe you will pull with make sure you are going the proper direction ( clockwise tighten counterclockwise loosen when looking at top of bolt ) and pull hard. This is a tricky situation too, its 50/50 that the bolt will break if you use too much force but if you pull with all you can and it comes loose its good, But if it breaks before you loosen it than it should of been replaced before you needed it removed. Also did you remove the COTTERPIN before spining nut?
Oct 22, 2010 | Toyota ECHO Cars & Trucks
Right front wheel bearing going out - how do you fix it?
Remove the wheel. Remove the center nut holding the c.v. shaft to the spindle. Loosen the bolt holding the tie rod to the spindle and set the tie rod out of the way.You may need a hammer for this. Remove the bolt holding the strut to the spindle. Remove the bolts on the upper and lower control arms. Remove the spindle and have the old bearing pressed out and the new one pressed in. Installation is reverse of removal.
Oct 06, 2010 | 1996 Honda Accord
Changing brake rotors
If you have changed your brakes before this is actually pretty easy.
Firstly you need to get the brake pads out ...
Easiest way to do this is to loosen the caliper bolts found on the top and bottom of the caliper. Loosen the top a few turns but do not remove it completely...Loosen the bottom bolt and take it all the way out....
You should now be able to shift the caliper up and out of the way....once it is out of the way you can then undo the rotor bolts in the centre of the rotor.
Slide them out of the way and yank off the rotor...replace the old with the new, tighten the rotor bolts slide the caliper back into place, tighten the bolts...
You're done...
Feb 23, 2010 | 1992 Honda Accord
On the Bench Oscillating Spindle Sander how do you lock the spindle so that you can remove the bolt at the top to change the sanding sleeve? When I try to loosen the bolt the spindle turns and I don't have...
Mar 09, 2009 | Delta Machinery ShopMaster SA350K Bench...
Delta SA350K Shopmaster Boss 1/4 Horsepower 1,724 Rpm Benchtop Spindle Sander With Complete Spindle Sander Set Logo
166 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
