-Washer Lid Switch 3949247 (3949237) for WhirlpooI received and installed a washer lid switch. Washer runs fine, only thing is when the lid is opened the washer does not stop. Lid switch is suppose to stop Spin Cycle, which it does not. Is there any thing that needs to be done to the switch prior to installing it?
  • preetirvine Dec 12, 2009
    Before the switch was changed, the machine would not spin at all, because the previous lid switch was broken. The whirlpool model number is LSQ8243HQO.
  • preetirvine Dec 13, 2009
    I figured it out. The lid switch screws were on too tight. This was not allowing the switch to completely shut off. When I loosened the screws the switch was able to shut off. Thanks for you for the follow-up.
    Cheers
    President:
  • 1,891 Answers
Why did you change sw/ did washer not spin ? or same problem . you may have a shorted of faulty ( new ) sw . just because its new doesn't make it good / ck with ohm meter .. if the problem is same as before sw installed the we need to lok at a different problem . like ( timer ) or wiriing . ) mm give me some feed back and wi can go / and model # brand .. . help is on it way .. mm
Posted on Dec 12, 2009
  • dennis dodge Dec 12, 2009
    ck the lid sw again it sounds like it's not openin & closing poperly.. ( may be that new is bad .. mm
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
Washer 110.92573110 works fine until it should rinse. It just stops and does nothing. It won't pump out the water. The schematic is unreadable. Do you have an electronic copy of the service documents...
check the lid switch,open and close the lid just a little and listen for a clicking sound,every time the lid closes and opens the switch should click,also you can set the timer to spin,open the lid and stick a screw driver into the hole where the strike on the lid would go into,that's the lid switch,if it starts to drain and spin then you'll know the switch is bad,the lid coulld be bad and not do anything and that's why you have to listen for the clicking sound,if it does click and the lid switch is good another thing it could be is that no cold water is entering the washer,when in rinse all that fills into the washer is cold water no matter what setting the water is on,this is to keep the clothes from wrinkling but it sounds like the lid switch
Apr 22, 2011 | Kenmore Washing Machines
RCA Whirlpool Model LSQ9665J will fill with water but does not agitate, spin, or drain on any cycle. Was working fine yesterday.
put the timer on spin,open the lid,with a screw driver push down on the lid switch,if the washer starts to spin and drain the lid switch is bad,also if nothing happens,lift up and push down on the switch if you don't hear a clicking sound the switch is bad,all it is is a safety so the washer won't run with the lid open.part number 3949247 and the lid switch is around 40 dollars,
Apr 02, 2011 | Whirlpool Washing Machines
Error on control panel "oL"
Hi
Error OL means that the washer has sensed an overload (OL) condition. It can also be a false error code appearing due to faulty lid switch. Sometimes this error code appears when lid is not closed/opened properly. You can check the lid switch for any disconnections, if the connection to lid switch is fine then use a multimeter to check the continuity of the lid switch. If the lid switch is fine then there is a piece of clothing stuck between inner basket and the outer tub. Disconnect the washer from the power outlet and then try moving the drum with your hand and check if it turns freely or is offering any resistance. If it is not moving freely then it is due to rusted drive shaft or motor. Hope this helps... Please post back if you need more assistance.
Daniel
Dec 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Hotpoint washer lid switch can you show me the lid switch
Smewhere around the rim of the opening in the washer you should see a little tab, this is the switch arm that the lid contacts when closed to allow the washer to run, it should be free to move
Aug 22, 2009 | GE WBSR3140DW Top Load Washer
Wont spin or drain.
Check your lid switch. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (part number 3949247). For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can by-pass the lid switch to drain the water by performing the following:
1. Unplug the washer and remove the console and case.
2. Unplug the lid switch connector from the timer and remove the entire lid switch assembly from under the washer case.
3. With the old lid switch assembly in hand, cut the square white connector plug off the end leaving about 2 to 3 inches of wire.
4. Clip the middle wire (green, or green and yellow) flush leaving the two black wires. Strip the wire ends and twist together using a wire nut or wire crimp. You have now made yourself a by-pass plug.
5. Plug the by-pass into the lid switch receptacle on the timer and place washer case back in place.
6. Plug unit back in and move the selector know to the final spin cylce. Pull the start knob and the washer should begin to drain.
It is strongly recommended that you DO NOT run the washer for exended periods of time with the lid switch by-passed as this is a designed safety feature of the washer. And, for your own safety, do not run the washer with the exterior case removed.
This is a simple and inexpensive repair. I hope this helps you. Let me know if you require further assistance.
Aug 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not drain
you need sto check your lid switch , open and close your lid a few times and listen carefully, do you hear a clicking noise?? if not the machine doesnt think the lid is down and wont spin for safety reasons, repalce lid switch
Feb 28, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not run pump
Check your lid switch. This is a tell tale symptom of a lid switch gone bad. The washer fills, agitates, but will not spin or drain. The lid switch is located along the right hand side of the lid opening on most models, but some newer models have a switch in the left rear of the lid. Simply open and shut the lid several times and listen for a distinctive "click" of the lid switch as you open and close the lid. A lid switch usually runs about $35 to replace. If you provide me with your washer model number (usually located under the lid somewhere) I can give you the part number you need. That is...if the lid switch is the problem. The only other problem that I have encountered that caused the same symptoms, was a bad timer. Timer vs Lid Switch: Lid switch is a cheaper fix. I would try this option first. Let me know if this helps and/or if you need more guidance.
Sep 21, 2007 | Whirlpool LSR6232J Top Load Washer
Will not drain
Check that the drain house is clear from kinked or clogged. Good luck!
Aug 17, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
620 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
