Question about Kenmore 72002 / 72004 Kitchen Range
I have similar problem with the Kenmore 72002 range, error code E-1 F1 which says to press the off/cancel button for 5 seconds until last error code displayed then unplug and wait 30 seconds and watch for a minute and if error still displayed replace control. Well I don't know what it means by control. What control? If this is needed to be fixed by a professional what is the cost?
    President:
  • 1,891 Answers
The control is the clock sometimes called e r c / elect/range /control. it probably has a bad membrain . . it is not a hard job . but when removing wires do only one at a time and make shure you know where the came from and where they go . its very hard to backtrack .. mm
Posted on Dec 12, 2009
Error code f1 e3
Try this out,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | Kitchen Ranges
The last two days I have the error message F1-E9 on my kitchenaide oven. I press cancel and it returns to normal. What does this mean?
F1-E9 - Stack Overflow.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
Jul 15, 2011 | KitchenAid KDRS807SSS Dual Fuel (Electric...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
What do codes e2 and f1 mean?
Here is what the manufacture says about it, my comments are below.
F1 E2 - UL A/D error(s)
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Phil's comments----->
F1 Codes are related to the control itself, if there was a storm, power outage, surge etc it could have damaged the control. Try resetting the board by unplugging the range or turning off the breaker for a couple minutes. Restart and see if that helps. If not you will need to replace the control.
The part number for this unit is 4453614 and runs just over $300.00
Apr 25, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Error F1E2 Whirlpool Super Cap Gas Range 465, oven crazy!
F1 E2
Nov 22, 2008 | Whirlpool GS460 Gas Kitchen Range
Range displays e2 f1 and beeps every so often
F1 E2
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
Kenmore range code f1 e2
F1-E2 - UL A/D Error(s) - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 05, 2008 | Kenmore 72002 / 72004 Kitchen Range
Kenmore 72002 / 72004 Kitchen Range Logo
121 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
