Question about Kitchen Ranges
E1 -f5- - Kitchen Ranges
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you mean that there is an error displayed as E-1/F-5 then I would say that it means that you’ll need to check door/latch switch and replace the component as it cannot be repaired. If you want more information please make sure to elaborate your concern and write down the model no# with the manufacturer’s name of your Range.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 12, 2009
My whirlpool oven is showing an E1 F5 code. It did it once but I can't clear it now.
E1 f5 code oven - YouTube
? 1:51
https://www.youtube.com/watch?v=5F1vwVpmG9U
Dec 28, 2014 - Uploaded by Jay Dornbos
Door locked then threw the code so now the door is locked and will not open. ...Whirlpool Oven - has E1 F5 ...
Nov 23, 2016 | Whirlpool Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
The range displays f5 e1 when i try to run cleaning cycle
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&*(
May 12, 2010 | Whirlpool GS460 Gas Kitchen Range
E1 F5 sign on panel control
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%^&*
Apr 20, 2010 | Whirlpool GR399LXHS Electric Kitchen Range
Self cleaning e1 f5
Mar 28, 2010 | Whirlpool GR448LXPQ Electric Kitchen Range
Self cleaning mode has a E1-F5- on display?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#$^YR
Oct 18, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
E1 F5 came out and door is locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^RF
Jul 20, 2009 | Kenmore 92022 / 92024 / 92025 / 92029...
E1 and F5 are on digital read out instead of 500degrees and cleaning
The E1 and F5 is a code that the door latching system is creating a fault. YOu might be able to take apart the door latch mechanism, and recondition it.
Apr 26, 2009 | Kitchen Ranges
Kenmore stove elite 790
**E-1,and F-5**
Some of the codes in the clock where programed backwards....some may show E-1,and F-5 and some may show F5 - E1.
F5 - E0 F5 - E1 and E2
Check door/latch switch
Replace switch if defective
OR
F5,6,7 EOC failure Replace EOC
Feb 22, 2009 | Kitchen Ranges
Whirlpool RF196LX Smooth Top Range
4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Oct 21, 2007 | Kitchen Ranges
Kitchen Ranges Logo
14 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
