Question about Bosch SHU43C05 Stainless Steel Built-in Dishwasher
Not filling with water - Bosch SHU43C05 Stainless Steel Built-in Dishwasher
  • 47 Answers
The rear decharge hose has to be up about half way to the top of dishwasher
Posted on Dec 12, 2009
Water does not stop filling with water
The possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.If the water fill vale is checked ok then other possibility is faulty water fill valve switch.The switch detects the required water in the washing machine and shuts the fill valve off,but if the switch is faulty then it will not shut the water fill valve off and this will not stop the water from filling and this overfills the water.So most cases the water fill valve is faulty and it has to be replaced.But if the fill valve is checked ok then other possibility is faulty water fill valve switch. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine wont fill with water when switched on
Fillingwith water:
The waterfill valve - The water fill valve is a mechanical and electrical part,the coils on the valve need electricity to mechanically open the valve to allowthe water to flow into the washer....myth....the washer pumps water into itself...no, itdoes not. The fill valve opens and the house water pressure pushes the waterinto the washing machine.
No cold wateror no hot water - The fill valve has two coils, one for the hot water and onefor the cold water. It is possible that one of the coils can fail and you loosethat filling ability. If the cold water coil quits, the hot will still work andduring warm fill you will get hot water only and during a cold fill you willget no water at all. If the hot coils quits, you will still have cold waterfill, cold water only on a warm setting and no water on a hot fill setting. Youcan No cold water or no hot water- The fill valve has two coils, one for the hot water and one for the coldwater. It is possible that one of the coils can fail and you loose that fillingability. If the cold water coil quits, the hot will still work and during warmfill you will get hot water only and during a cold fill you will get no waterat all. If the hot coils quits, you will still have cold water fill, cold wateronly on a warm setting and no water on a hot fill setting. You can testa fill valve live for 120volts, power to a fill valve coil and no fill = a bad fill valve. You can also testthe coils for continuity, nocontinuity = a bad fill valve. Some Maytag washers have a fuse in the fillvalve circuit, if this fuse let go the washer will not fill. Fill valves canalso from time to time stick open and not stop filling. If you have to shut offthe fill valves to stop the water fromfilling in the washer, you have a bad fill valve and you will have to replaceit.
Water level controls - The water levelcontrol is also know as apressure switch, this is where you set the water level ( small - medium - large). The water level control is responsible to shut off the power to the fillvalve and direct that power to the timer so the washing machine can start up.The WLC has electrical contacts in it that sends power to the fill valve and whenthe WLC is satisfied the water level is correct the electrical contacts openpower to the fill valve and send the power to the timer and the washer starts.Picture of this here. How the water level control knows when it istime to shut the water off is, a air tight hose runs from the outer washer tank to the waterlevel control. As the water fills the outer tank air is pushed up the hose,depending on which setting you have made ( small- medium - large ) is takes acertain amount of this pressure to make the WLC cycle over and shut off the waterand send this power to the timer. If this hose develops a leak or a pin holethe washer can over fill as the WLC may not be able to shut the water off. Thewater level control can also break down and allow the washer to over fill aswell.
Testinga water level control or a fill valve can be done by using a Testing a water level control ora fill valve can be done by using a ohmmeter or a voltmeter. Testing a waterlevel control or a fill valve can be done by using a ohmmeter or a voltmeter. Testing a waterlevel control or a fill valve can be done by using a ohmmeter or a voltmeter.
You can get required parts from www.repairclinic.com
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Jan 16, 2010 | Zanussi FJS1225W Front Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
How do you remove the water pump on a 2006 monte carlo
  1. Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  5. Remove the water pump bolts.
  6. Remove the water pump and gasket.
  7. Clean the water pump mating surfaces
    1. Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
    2. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolts.
  2. Install the drive belt.
  3. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
  4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Inspect for leaks.
Hope this helps
Oct 01, 2009 | 2006 Chevrolet Monte Carlo
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
My kemore 80 series washer will not fill up
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
May 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washing maching not filling with water
The problem is most likely the water fill sensor switch. If it is telling the machine that it is full, it will go right to agitate.
Apr 25, 2009 | Roper RAB2121KW Top Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
Water level switch doesn't shut off the water
Washer Basics: Filling with water:
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Nov 13, 2008 | Maytag PAV2300 Top Load Washer
Dishwashers Logo
66 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
