Question about Air Purifiers
Filter how do i find out where my filter is located, i need to replace it.
  • 1 more comment
  • Vodkaman1 Feb 20, 2008
    Where can I purchase replacement filter ?
  • Anonymous Aug 27, 2008
    I cant get the back off to change the filter on my Ecoquest. How can I do this?
  • Anonymous Dec 18, 2008
    I have a AMCOR model AM-130 and I can not find a filter for it. Can you help? Thanks, Mary mfosemd@yahoo.com
  • 397 Answers
Get the model# and manufactuer for me
Posted on Jan 20, 2008
How to change air filter on 2006 Toyota Hiace SLWB diesel automatic?
Hi josephjohn,Here are instructions on How to Change Cabin Air Filter in a Toyota. It is recommended to replace this filter at every oil change.
Jul 29, 2014 | Filter Queen Defender Air Purifier
Unable to remove back panel
There are two Philip screws located on the edges of the back. Remove them this will allow the back to be taken off. Then remove the two screws at the top bracket that holds the filter in place..Ypu can remove the filter and bracket No need to remove any more of the screws on the back . From there you will see the plates and another filter. You can get at them by removing the two screws on the left and right of the plates..You can take the plates and filter out for cleaning and change the bulb if needed....NOTE; the filter on the back is resting on a activation switch just make sure when replacing the filter and bracket is pushed down to activate or the machine will not work..good luck....
Mar 24, 2014 | Ecoquest Fresh Air Air Purifier
How i can change the cab filter from daewoo nubira 2
Your owners manual should show the location and exact procedure for removing them to change them. They should be located up near the air inlet in the cowl, which would place them in the vicinity of the door pillars on either side- in the airflow of the entering air. If you already have the replacements, look for a removable panel (with 2 or 4 screws) slightly larger than the filter is wide and slighly longer than the filter is tall.
Feb 04, 2012 | Air Purifiers
I just replaced my filter for the winix 5300 model and the replace filter indicator does not seem to turn off. Are there any solutions or procedures as to how i should go about this matter?
Remove the front cover and locate the FILTER RESET button below the DUST SENSOR level display indicator lights. Press and hold this button for 3 seconds until the unit beeps and the REPLACE FILTER indicator light goes out.
Apr 02, 2011 | Winix PlasmaWave 5000 Air Purifier
I have a Kenmore Progressive 295 air purifier. I have the model number for the large filter and the dimensions of the carbon filter but, because it is older, can't seem to locate comparable replacement...
Have you looked at Sears' online parts store? Type in the model number, and it will display available replacement parts.
http://www.searspartsdirect.com/
You can also get there from the Sears home page:
http://www.sears.com/
Click "parts direct" at the top of the page.
Mar 10, 2011 | Kenmore 335 CADR Air Purifier
How do you reset the filter reminder warning light?
Filter Replacement
Filter Replacement Indicator:
Your Defender® is equipped with a Filter Replacement Indicator located on the front
panel. Anytime this red indicator flashes, it is recommended that you call your authorized
FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops
flashing and remains solidly illuminated, it is recommended that you change your filter. To
receive full benefit from your Defender® and to extend your warranty, it is strongly
recommended that you follow the filter replacement schedule suggested above. Under higher
pollution levels, your filters will need to be replaced more frequently.
The Filter Replacement Indicator is operated by filter time in use and is controlled by an
onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter
Replacement Indicator will begin to flash. It will continue to flash until the you reach 12
months of time in use, at which time the Filter Replacement Indicator will stop flashing
and remain solidly illuminated.
After replacement of your Medi-Filter® Cartridge, you must reset the Filter
Replacement Indicator's timer. When the timer has been properly reset, the Filter
Replacement Indicator will turn off.
Resetting the Filter Replacement Indicator Timer:
After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the
Filter Replacement Indicator's timer can be reset by performing the following sequence of
steps:
1 Plug unit into outlet.
2 Press power On/Off switch to the On ("I") position.
3 Allow unit to start running at low speed.
4 PRESS and HOLD both the Up and Down arrow buttons until the Filter
Replacement Indicator starts to blink.
5 Release both the Up and Down arrow buttons.
6 While the Filter Replacement Indicator is still flashing*, again PRESS and
HOLD both the Up and Down arrow buttons until the Filter Replacement
Indicator turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will
turn off and not flash again for 11 months. If the Filter Replacement Indicator remains
on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when
the buttons are pressed the second time. The Filter Replacement Indicator will continue
to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Note: Under higher pollution levels, your filters will need to be replaced more frequently.
Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call
1-440-846-7800 for the Distributor nearest you.
http://www.filterqueen.com/pdf/defender.pdf
Mar 02, 2011 | Filter Queen Defender Air Purifier
I've replaced the filter. why won't the red replace filter light shut off?!
Remove the front cover and locate the FILTER RESET button above the dust sensor level indicator lights. Press and hold this button for 3 seconds until the unit emits a beep and the REPLACE FILTER light goes out.
Sep 03, 2010 | Winix PlasmaWave 5000 Air Purifier
Resetting the change filter indicator
Turn off the unit
Open the filter cover
On the top right corner, there is a small hole
Push a paper clip into this and the change filter light will stop blinking.
Hope this helps!
Nov 04, 2007 | Neoair Plus Air Purifier
Air Purifiers Logo
158 people viewed this question
Top Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
