Question about Linksys Wireless-G WRT54G Router
Will not connect with windows 7 - Linksys Wireless-G WRT54G Router
  • 484 Answers
Go to Start | Run and type CMD, then Enter.
Ping 192,168,1,1 and see what comes back. Then type IPCONFIG /ALL and see what you get in terms of IP addresses.
In Internet Explorer, type 192.168.1.1 and you should get to the Administration pages.
From there you should be able to sync up with your router.
Then call LinkSys' tech support phone number and ask them for assistance. They are there 24/7 and will help you right away!
-a.
Posted on Dec 12, 2009
I have inspiron dell mini 1018 and i instaled windows 7 ultimate but i have previously windows 7 starter so this cause problems how can i remove windows 7 ultimate and stay work on windows 7 starter i...
click start control panel view your network and staus tasks locale area connection diagnose or connect to a network or troubleshoot problems
hope this helps
Oct 21, 2011 | Dell Inspiron Mini 10 Notebook
Tip
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Instructions
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
References
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
Regards
MultilinkEnt.
on Jun 05, 2011 | Computers & Internet
Tip
How to determine your computer's MAC address Applies to Windows XP, Windows...
Applies to Windows XP, Windows Vista and Windows 7
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Next at the command prompt type "ipconfig /all" and press enter
At this point all your active connections will list on the screen. Note you may need to scroll back up the window to get to the MAC address info you need. Also keep in mine if you are connected to your wired or wireless connection because both will have a MAC address assigned to them and they will be different.
4. Look under the Local Area Connection if connected to your network via a wired connection or Wireless Network Connection if connecting via a wreless connection.
Once under the right connection you will want to look for the line that shows "Physical Address" this will have what the network cards MAC Address listed.
Note if you have Windows Vista or Windows 7 and you access a lot of different networks then you may have a lot of Tunnel Adapters list that causes overflow in the CMD buffer. If this happens the top part of the "ipconfig /all" report will get cut off. To fix this all you need to is turn off IPV6 in your network properties and reboot your computer. This will remove the ones that are tied to IPV6. After you reboot you should be able to see MAC address for your netork devices. After you get the MAC address it is recommended that you turn IPV6 back on because there is some programs that have been writen for IPV6 for when it becomes a standard.
How to turn off IPV6 in Windows 7 and Windows Vista
Here is an example of what "ipconfig /all" looks like on a computer running Windows 7
Other Helpful Links
How to allow ping request through Norton Internet Security 2010 Smart Firewall
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Aug 21, 2010 | Computers & Internet
How connect to windows 7
This device does not support windows 7 and there is no driver for it. You can connect it to windows 7 though if you install windows XP compatibility mode for windows 7.
You can download and install this mode from this link to Microsoft: http://www.microsoft.com/windows/virtual-pc/download.aspx
Please note: Windows XP mode for Windows 7 uses resources so it is good if you have at least 4GB of RAM.
Chris
May 20, 2011 | Agfa SnapScan 1212u Flatbed Scanner
I have a 3G dongle (ZTE MF626) and can not get access to the internet. I tried with two Laptops via Wireless. One with XP and the other with Windows 7. The wireless is recocnizing the ESR 6650 but can not...
Try this link
The Connection Manager installed from the USB modem does not include Windows 7 Drivers.The Connection Manager M03 does include Windows 7 drivers.
For Windows 7 support do only one of the following two options:
a) Update your currently installed Connection Manager using the Windows 7 driver tool or...
b) Install the new Connection Manager (M03) after un-installing your current version.
Nov 01, 2010 | Computers & Internet
Tip
Here is how to connect your Windows 7 installed notebook to an external display
Most of the notebooks that were manufactured in the past two-three years come with a HDMI port along with the old VGA port to connect your computer to an external display. Connecting and activating an external display on a Windows 7 machine is pretty simple.
Here is how to connect your Windows 7 installed notebook to an external display:
1. Connect your Windows 7 laptop to the external display using VGA or HDMI cable.
2. Then, switch on your Windows 7 laptop and also the external display.
3. Once Windows 7 is up and running, type Mobility Center in Start menu search area and hit enter to open the same.
4. If you have connected your Windows 7 machine to the external display properly, you should now see Display connected text under External display section of Windows Mobility Center. To use the connected external display, click Connect Display button. You should now see your Windows 7 desktop in the external display as well.
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays
on Jun 18, 2010 | Computers & Internet
Tip
How to connect Laptop to an External Monitor?
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays.
on Jun 14, 2010 | Computers & Internet
Windows 7 Wireless connection problem
Disable IPv6 from your Laptop & then check ur Wireless Connection...
Also let me know the status...
Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
Tip
How to determine what your computers IP address is
How to determine what your computers local IP address is
3. Next at the command prompt type "ipconfig" and press enter
At this point all your active connections will list on the screen. Note you may need to scroll back up the window to get to the connection info you need. Also keep in mine if you are connected to your wired or wireless connection because both might have an IP address assigned but you can only be actively connected to one at a time not both.
Once under the right connection you will want to look for the line that shows "IP Address" this will have what the computers current IP Address is. Note if you have Windows Vista or Windows 7 it will be listed as "IPv4 Address". Also while you are here take note to what the "Default Gateway" is because if you are trying to network computers together you want to make sure they are connecting to the right network.
Here is an example of what IPCONFIG looks like on a computer running Windows 7
Other Helpful Links
on May 24, 2010 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
