Question about Dishwashers
I have a kenmore coldspot side by side that has stopped producing cold in both refrigerator and freezer. I have cleaned bottom coils but still not working.
  • renshaws May 11, 2010
    where is the fan on your model and does it have a vent in front near the floor?
    President:
  • 1,891 Answers
Ck for ice in back of freezer / the evap coil may be iced over due to a defost problem . make sure both fans are going inside and under in back .. feel the compressor / is it hot if not it may not be running . this could be relay . if none of thes work you may have a under charge ( loss of gas and need a recharge. mm
Posted on Dec 12, 2009
SOURCE:
Kenmore coldspot refrigerator
It has to be internal, you may find a fan has failed, not uncommon, check for a whiring noise when you shut the door, it should come on & turn off when opened.
Nov 22, 2013 | Refrigerators
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
I have a Kenmore Coldspot Top Freezer refrigerator. Everything in the freezer is really, really cold, but the refrigerator is not. I tried to clean the coils at the bottom, but I could only get to the one...
There is an ice blockage between the freezer and the refrigerator. Cold air passes from the freezer into the refrigerator in the back behind the plastic housing with the temperature controls. Empty your freezer and remove the bottom panel. You will see that everything is frozen. Carefully remove this ice until you can clear the passage to the refrigerator. It may be helpful to remove the temperature control housing in the refrigerator as well to see when the ice is cleared.
Oct 03, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge side not cooling
the coils are at the bottom but that dose not sound like the problem u need to check the de frost
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Dishwashers Logo
107 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
