Question about Stanley Bostitch STB-MIIIFS Flooring Stapler
I have a #MIIIFS stanley bostich floor stapler that is less than a year old. It won't drive a staple anymore. It started to drive it about every other time then it got to be every fourth and then every tenth and then not at all. It appears that the plunger that drives the staple just won't retract far enough to allow the staple to slide into place. I have another gun just like it that works fine and in comparison the good one retracts about an eighth of and inch further than the bad one. I can't even force it into the gun far enough to allow the strip of staple to fall into place. The gun fires well with plenty of power and makes dent where the plunger hits but no staple.
  • 576 Answers
First step -- have you oiled it recently? If not, do that first and cycle it a bit to see if that fixes it. If not, take it apart and look at the striker pin carefully. See if there are any burrs or rough spots on it. Also, check the pieces it runs against. Smooth out any burrs with fine sandpaper or a fine file. Here is an exploded view to help you disassemble if necessary
http://www.bostitch.com/catalog_images/web_pdf/IP1084-1REVP.pdf
If any parts are too damaged or worn to work well, here is a parts list:
http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=MIIIFS&serialNum=
Hope this helps. Message back if not.
Posted on Dec 12, 2009
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
Which nailer do i need to nail down 5/8 bamboo prefinished floor i have the basic nailer for 3/4 flooring is there an attachment to add to it
Stanley makes a foot, part number MIIIFOOT-KIT, for the MIIIFS flooring stapler that prevents scratching of prefinished floors.
Jan 20, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
My bostich flooring staler wont fully drive every staple and it is getting wors....it is not leaking air
Your compressor needs to be checked first. There is an air pressure regulator on most machines - be sure all is in working order. It might help to be sure you're playing any lubricants in the stapler configuration as well.
Nov 05, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
My Bostitch MIIIFS Floor Stapler wonk work
Sounds like you have a broken driver blade.
Sep 27, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Will not staple air coming out of frame cap ?
it's a blown seal do'es work sometime when you disconnect the airhose and reconnect?If so thats the problem
May 11, 2009 | Stanley Bostitch STB-MIIIFS Flooring...
I AM HAVING TROUBLE OUT OF MY BOSTITCH MIIIFS FLOOR NAILER
D Farley,
I repair these nailers all the time. Anytime the nail or staple is bending you have 2 causes. Either the stapler has a broken blade, the magazine is loose on the foot gate, or you are shooting into plywood over concrete. that is allowing the staple to hit the cement subfloor. Use 11 /2" staples on 3/4" wood floor over 3/4" plywood when over concrete.
Dec 16, 2008 | Stanley Bostitch MIIIFN Flooring Nailers
Stanley Bostitch STB-MIIIFS Flooring Stapler Logo
384 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
