Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
One of the burners won't light.
One of the burners on the top of my Jenn Air slide oven won't light. The 'clicker' isn't clicking. Is there anyway I can fix this, or do I need a repairman. Thanks
  • 126 Answers
HI...TRY TURNING ON ONE OF THE WORKING BURNERS AND LEAVE IT IN THE "CLICKING " POSITION AND TURN ON THE BURNER THAT DOESNT LIGHT.DID IT LIGHT?IF SO YOU WILL NEED TO REPLACE THE SPARK SWITCH WHICH IS LOCATED BEHIND THE KNOB.IF NOT SPARK MODULE IS BAD.HOPE THIS HELPS.PLEASE RATE MY RESPONSE :)
Posted on Dec 12, 2009
    President:
  • 1,891 Answers
Jen air ranges use a sw harness. when you order one you get all 4 in a harness. the problem is the sw just behind the knob . about 40.00 for part . hope this helps ****
Posted on Jan 11, 2010
SOURCE:
I have a Jenn air dual fuel. The 5 burners on the top will not light without a match. There is no click sound.
If they won;t light on there own after cleaning then the spark module for the burners may be faulty
Mar 06, 2014 | Kitchen Ranges
How do I lift the stove top to turn off pilot model # FGF366DCB?
there isn't a pilot in it,it has an electronic spark module in it.what problem are you having?when you turn it to lite it you'll hear a clicking sound,that's the sparking that lites the gas just like you're gas grill.if you want to remove the top you have to remove the two phillips screws out of each burner head,sometimes they don't come out and you have to drill them out,if the burner isn't shutting off the gas valve could be broke or the knob could be broke,if it's clicking just unplug it and you can lite the top burners with a match or bbq clicker to lite them until you get it fixed depending on what problem you are having.if the gas won't shut off by turning the knob you'll have to shut down the gas at the valve that feeds the stove.but like i said if you want to lift the top you have to remove all the screws in the burner heads.hope this helps you out.http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-FGF366DCB/1428/0124002?pathTaken=&prst=0&shdMod=FGF366DCB go to this site and you can look up your machine.
Sep 03, 2011 | Frigidaire Ovens
Two burners on jenn air counter top make sparking sound but burners won't ignite
turn electricity off to ignitors. remove grates and clean up the burners good, they might have a clogged up hole. gas may not be coming out of burner holes. good-day !! if all else fails, just use a wooden match to light that burner.
Jul 11, 2011 | Microwave Ovens
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
Jul 31, 2010 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jenn-air slide in range/convection
I put a $.12 capacitor on the display board and the display came back. capacitor in position c3, part from mouser electronics, #746-uvy1v680med
Dec 19, 2007 | Kitchen Ranges
its not a loose wire. jenn-air is famous for having to replace the display board. once you replace it it will be fine
Nov 28, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
Oct 29, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
156 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
