Question about Vizio GV42L 42 in. LCD Television
I bought a 42" vizio lcd tv a year ago. The other day it just up and quite working. The picture went black and no sound. It would not even shut off, I had to finally unplug the tv to shut it off. I tried it again the next day. I plugged it in and then turned the tv on. Still no picture or sounds just a black screen. I checked my cables over to make sure the tv was recieving a signal. My cables are fine I used them on another tv they worked fine. So not sure what it could be. Is this something I could fix?
  • FTTH Dec 12, 2009
    I have never soldered on eletronics before is it pretty hard to do? Also do you have any directions on how to go about checking it out with the meter.
  • FTTH Dec 13, 2009
    toke out the power board and could not see any resisters or capasiters that looked swelled or blown or burt. I found online I can order a new power board for around $68. Do you think it would be worth my time and money to try it and see if thats the problem. Don't know what else it could be at this time
    thanks
  • 10,515 Answers
I am familiar with this type of TV, I haven't seen a lot of bad Vizios though. I think the likely problem is your power supply.
Is this something you would like to repair yourself? Do you have a multimeter and good soldering tools?
If so, this area of the TV comprises some fuses, a bridge rectifier (4 diodes) a couple of capacitors and a regulator that would need to be checked. If it all checks OK, we can move on to something else.
If you take it to a shop, I think you are looking at a $35 estimating fee and a $200-$300 repair bill.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
  • taran_2005
    taran_2005 Dec 12, 2009
    Thanks for your Response!!
    These do Need to be Diagnosed with Proper Instruments. The only thing you could do, ( Works Most of the Time ), You could Open the TV and Pull out the Power Supply Board. Once you Pull that Out, Check the Diodes and Resistors. Most of the Times, you would find the Defective one is Either Swelled / Bulged / Blown. You could easily catch it with Naked Eye. Then, Note Down the Part Number which is Engrossed on it. Go to Radio Shack / Local Hardware Shop or Order Online the Capacitor. You need to then Solder it.
    Once Done, it would be all Set.
    Note - Working on These Models are Dangerous without any Prior Knowledge of Electronics.
    The Best i Could DO, i am Offering you a Link for Service Manual. Read it Carefully. It would have all the Details and Diagrams and Part Numbers.
    http://www.scribd.com/doc/4788185/VIZIO-...
    Hope i helped you.
  • taran_2005
    taran_2005 Dec 13, 2009
    Thanks for your response!!
    As there is no Blown capacitors or Diodes, you also need to check the Inverter Board and Video Card. No doubt, the chances are less, but could be the problem.
    Thanks!!
How do i fix a vizio 42" tv with a black screen, no sound
THE MAIN BOARD AV BOARD HAS WENT OUT JUT HAPPENED TO ME TODAY
Feb 28, 2013 | Vizio Razor M421nv 42" 1080p Hd Led Lcd...
Replacing a Vizio Backlight Inverter
I have a television that did this. The picture went out but it continued to have sound. It was the projector bulb. I ordered from a dealer on ebay, very resonably priced. It came with instructions on how to install it and was a very easy fix.
Feb 25, 2012 | Vizio 42 in. LCD TV
Vizio VW42L went black screen, no sound could turn on but not off, with remote or on the side. Called a repairman, decided to purchase a new TV. Year gone by, plugged it in and it has worked for several...
Yes,the tv main Tuner signal board it is the problems and the causes it have intermittents shorts in sides.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal boad for the replacement.
Jul 10, 2011 | Vizio 42 in. LCD TV
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
Screen went black on Vizio 42" plasma TV
The cost to repair it might not be a worry, parts for those types of sets are not available, the plasma style sets are replaced by LCD/LED.
Oct 14, 2017 | V, Inc. Vizio P4 Plasma Television
Vizio GV42L
Call vizio asap they will have a tech come and fix it free.. after the manufacture warrenty runs out they want to charge you 6--$ to fix it here is the number! 877 698 4946
May 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV42L 42 in. LCD Television Logo
105 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
