Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Re: when incoming or out going we get a line on the right side of the page
What can be done to fix this problem when faxing a page or incoming of a fax we get a dark line in the right hand side of the paper
  • Anonymous Sep 07, 2008
    I have the same issue ,,,only from printing a received fax and from top loader not from glass scan.... on all in one 7100 series......I'm getting multiple perfectly straight verticle lines black and also color
    Genius:
  • 3,587 Answers
Hmmm...does this happen on printing or copying?
Posted on Apr 30, 2008
For some time now there is a black line down the right hand side of the page. I suspect there is dirt on something, but have no access to the inside of the machine. Yesterday there were a few copies that...
This is almost for sure going to be a fuser fixing sleeve defect. I just repaired one of these the other day. An easy way to tell for sure is to print a page, and pull out the power cord when the page is halfway through the printer. Open the back and pull out the paper. More than likely you will see the defect on the portion of the page that has gone through the fuser (directly behind where the paper comes out, but not on the part that hasn't. This can be a reliable repair if done by an experienced tech. I usually charge $75 to do this on this model. Make sure if you get the repair done that the tech uses only a brand name fuser sleeve. If you are in the sacramento, ca area, I can repair it for you.
Sep 29, 2010 | HP LaserJet 3050 All-In-One Printer
Recieve the fax and print the pages well. But, when I send the fax to other fax it prints two black lines on the right side.
The problem should be from the printer fuser assembly, the other party will need to replace there fuser assembly on there printer, once that is done, the problem should be fix.
Take care.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
WE HAVE A FAX MACHINE THAT HAS A BLACK LINE GOING DOWN THE PAGE WITH FAX IN AND FAX OUT
For outgoing fax lines, check your scaner rail for any streaks, dirts or similar and clean scaner.
For incoming fax streaks, you can only check your drum unit for lines on surface and replace it, or lines is there because other side has dirt or similar on their scaner.
Hope that helps!
Aug 09, 2010 | Office Equipment & Supplies
There are thick black lines down the incoming fax pages of our Brother Intellifax 2800. How do I fix it?
You need to open the front cover of the machine and remove the cartridge( drum and toner) On the tope right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 08, 2010 | Brother IntelliFAX 2800 Laser Fax
Brother 465 CN Won't pring in fax mode
It's all part of the setup that's in your manual. If you use the menu, go to reports and print the user settings you can check if it's set to hold faxes in memory or to print right away. It's all done by user selection.
Oct 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Ricoh Aficio 350 change number of rings before fax answer and/or auto detect incoming fax.
Can't be done..this fax can only operate on a dedicated line, and it picks up right away. Sorry.
Mar 25, 2009 | Ricoh Aficio 350e Printer
Brother MFC-7420 doesn't receive faxes - send out is OK
If you have the book, go through the setup procedure as if you were installing it for the first time. If you don't have it, go to the Brother website and download it.
Mar 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Incoming fax shows one half of the page
The Thermal printhead is most likely burned out on one side and will need replaced. It could also be the printhead connector has worked loose and is only making partial contact. Remove the connector and reinstall. If that doesn't solve the problem then it would be cheaper to purchase another fax.
Jan 22, 2009 | Sharp UX 108 Roll paper Thermal Fax
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
96 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
