Question about RTO PasLode 900420 Impulse Framing Nailer
Gun does not fire every time
Paslode gun model 900 420 does not fire every time. I have to keep pushing and pulling the trigger before it will drive a nail. I have clean and oiled it twice!
    Problem Solver:
  • 14 Answers
When you cleaned it, you may have pinched the large brown o-ring that is around the fan. Take gun apart again and reassemble. before you place the orange head valve cover on, press the nose of the gun into a wood surface and assure the o-ring goes into chamber unrestricted. Basically, the aluminum fingers of the cylinder should not pinch off the o-ring.
Posted on Jan 10, 2010
Testimonial: "I ordered a rebuild kit and this took care of the problem!(spark plug, new filter o ring etc) Thanks for all the assistance!!!"
  • 142 Answers
Make sure the safety is being pushed in all the way
it will not fire unless the safety is fully engaged
Posted on Dec 12, 2009
    Problem Solver:
  • 5 Answers
There might be an internal issue with the gun regarding the technical parts which helps in the process of firing easily. My father has a collection of guns as he is a retired officer of an armed force but he took great care of them all including regular oiling, testing their reliability and never forgets a concealed carry holsters while riding to avoid the damages that can be done due to falling down or being misplaced.
Posted on Jun 26, 2018
What's your problempaslode gun will only fire when pushed down twice before firing?
the saftey switch that is triggered when u pick it up maybe a little sticky or if the switch is through wires then it could be the connection
Jul 10, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode misfire
not sure what this is by your description but here is a link to a forum that talks about paslode missfire nailing gun. hope this iw what your trying to fix? to ask questions you will have to joing the forum. Paslode Cordless Framing Owners Fix For Misfires
Nov 03, 2017 | Air Tools & Compressors
The problem of intermittent firing began some time ago. Now the gun will not fire at all. The gas bottle is full and the battery is fully charged. I disassembled and cleaned the gun. It subsequently fired...
what is the expiration date on the bottom of the fuel cell?? Also what were the condition of the o rings and did you relube with a good quallity oil. What I would do is remove the front assembly to expose the fan only and then insert a battery, pull the trigger and the fan should run for a few seconds, next there is a roller lever towards the top, depress it keeping fingers away from fan and again it should run for a few seconds, next depress and hold the lever and then pull the trigger and you should see it fire, repeat this several times, that will narrow it down to the spark unit/electronic assenbly or the cylinder.
Jan 09, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Plaslode im250 second fix nail gun fires intermittently. Gas is loading fine and trigger working only fires about one in every ten pulls of trigger
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Dec 31, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framer when you depress trigger there no resistance and it does not fire
Paslode framer has a lever inside of trigger that may be bent or missing. Easy to check. Remove air line and nails. Remove trigger by pulling pin. Check under trigger for missing parts. Test gun by connecting to air and place nose of gun against wood or hard rubber and then depress firing pin. If gun fires then problem is with lever under trigger or safety mechanism which is in two parts. Check safety for bent or broken piece, usually upper part will be missing lip that actually pushes on the lever. If however gun does not fire when firing pin is depressed, time for replacing orings in gun. Parts are available at www.toolpartsdirect.com . Good luck with your repair and post again if you have other questions.
Jun 30, 2010 | NRS Paslode 501000 Powermaster Plus...
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
My paslode keeps flashing green red after it fires once. I have checked the wiring and all seems fine. The trigger and contact switch are both working but when it sparks once it cuts out
is the fan working? if you have the tool partially disassembled and it seems that you know what you are doing you can fire the tool in this position to check for the entire function. When was the last time cleaned? To fire and test motor connect the head assembly back up laying to side so fan can turn freely then push trigger fan should come on and run for a matter of seconds, next depresss the safety switch and then trigger to get gun to fire, look at spark for crisp action, fan should be on and again run for a few. If not then you have a problem with either fan or spark unit. You can go to Paslode.com and type in your model and they have a troubleshooting guide in the manual that might help.
Sep 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
803 people viewed this question
Top RTO Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Jim Goldsmith
Jim Goldsmith
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
