Bose model AV3-2-1
You must unplug the unit from the wall for 1 minute (this allows the unit to reset). Then plug the unit back in but before you turn it on press and hold the eject button and then turn it on, it will eject the disk.
You made my day yeroc, thank you.
WOW the reset TOTALLY worked first time I tried it. Total time to fix: 2 minutes. You rock! Thanks so much!
Could be jammed, sometimes this happen, if you want you can take the screws off and take cd out and see if motor is bad by checking voltage to motor ejection unit, or try unplugging unit for a few minutes and immediatly try to hit eject
I have the same problem. The DVD is stuck in the unit with no sign of it releasing anytime soon. I tried unplugging the unit for over a minute & then first holding the eject button before turning the unit on, but nothing happened. Please help!
My e-mail is [email protected]
Thanks!
dvd stuck
Where are the screws to undo?
