Question about Whirlpool MH1170XS Microwave Oven
Can i buy a bulb at the local hardware that will replace whirlpool Part Number 8206232
  • Whirlpool Master
  • 9,098 Answers
Yes, you should be able to match them up at a local hardware store, or home center.
But I'd recommend a non-Chinese type if you can them. They hold up better.
You can also find links to helpful exploded view diagrams and online part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Dec 13, 2009
I have a Kenmore microwave mounted above my stove. The light that lights my stove is blown and I can't find the right replacement bulb. It has two little prongs that should fit into the unders
Are these little spot lights? About the size of 1/2 dollar round and maybe 1.5 -2 inches long? 2 prongs about 1/2 inch apart? Take one of those lights and show it to a local hardware dealer like "Lowes". There are may types and some are 12V some are 110V. Thats why I suggest showing to the local hardware guy.
Jan 12, 2015 | Microwave Ovens
I have an atlas waldorf wall oven which has a blown light bulb. Can i fix it myself or do i have to call the pros.to fix it?
isolate the supply to the oven
remove the lights panel screws and unscrew or rotate the bulb
look at its number they are usually a standard size of screw in
but its an OVEN BULB and it is treated glass !!!
and must !! be this type or it will pop quite quick and loud
the local hardware shop will have them i get them for 1 pound for 2 local
screw in a new bulb but use a bit of tissue to hold it dont touch it with your hands
fix the panel back on and test
its an easy job you can do yourself
Aug 13, 2014 | Microwave Ovens
The lightbulb cover on my whirlpool WFE361LVS wont unscrew, how do I get it off, I need to change the bulb
Most microwave ovens lamps' outlast the life of the microwave. So, most of them do not have access covers for the oven lamp. The lamp has to be replaced from inside the unit. Also, the newer units tend to use bulb assemblies rather than just a screw in type bulb. Call Whirlpools 800 help line or your local appliance parts store and have them look it up for you.
Sep 19, 2013 | Microwave Ovens
What replacement bulb?
I dunno ... what replacement bulb??? Is that question or a statement?
May I suggest you open the access panel if there is one or the oven cover if there is no access panel. Take the lamp out. There will probably be a number on it ... and that is what you want.
Find it at your local hardware store or appliance parts place ...or search it at Repairclinic.com
Oct 10, 2009 | Frigidaire FMV145K Microwave Oven
I need to know the size of the lightbulb for lighting the work surface below the microwave; they have them at my local hardware (Canadian Tire) but there are a lot of different sizes, I could not see the...
The bulb is a halogen (part number 53001905). You can view the bulb at searspartsdirect.com. Type in your model number and look under the "Base/Latch Board Assembly" heading for item 6. Although it does not list the size, it does list the type and part number. Your hardware store may be able to cross this number for you and find the bulb you need.
PS There is a better view of the bulb at appliancepartspros.com. Just type in the part number above and you will see a photograph. Are you in Canada? If so, you may enquire one of these sites also to see if they will ship to Canada.
Jul 27, 2009 | Maytag MMV5207 Microwave Oven
Need to replace the surface light in GE JVM1490BD 003
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Or you can find helpful exploded view diagrams and order parts by entering your full model number here.
You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jun 28, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Replace light bulb on Whirlpool GMC305PDS07 Microwave oven without a $150 service call. (The bulb does not unscrew from inside the oven.)
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Mar 03, 2009 | Whirlpool GH7145XF Microwave Oven
Whirlpool MH1170XS Microwave Oven Logo
71 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
