Question about Motorola Mobility RAZR V3
Says searching my motorola c78 wont stop searching for signal
EWB100 Wont connect to deployment application
Joe-
Contact Motorola Solutions ( Get Support ) for assistance.
Mark
Motorola Mobility Support
Sep 24, 2012 | Motorola EWB100-WR KIT:EWB100 SYSTEM KIT
Cannot find any one to unlock a zte telstra prepaid phone model t100
Well sorry but at the moment nobody support that series of phone, perhaps it will be covered in a while, i suggest that you just keep searching over time to come and see if it will become supported?
Oct 13, 2011 | ZTE Corporation C78 Cell Phone
Wont stop on a station when search button is pressed
The autosearch feature stops on stations based on a preset threshold for radio station signal strength.
If your radio has done this on both AM and FM from when it was new, it is probably an internal problem with the circuit board electronics or possibly because you are in an area where strong signals are absent (such as a rural area or inside a building that interferes with signals).
If the radio won't stop searching at all, the 'Search' button' may be stuck.
If you find that your radio is skipping stations only on FM, it may be a defective or broken external antenna or, again, maybe you are in an area where strong signals are absent (such as a rural area or inside a building that interferes with signals).
Hope this helped.
Feb 03, 2011 | Dewalt DC011 AM/FM Radio
Motorola razr v3 not catching signal
Have you used the external antenna port? If this is damaged it renders phone useless. Somehow connected to main antenna.
Jul 09, 2009 | Motorola Mobility RAZR V3
Motorola ZTE C78 Cell how do you shut off message ringer when getting text massages???
what you do is you go to main menu then go to settings then sounds find alert sounds or somthing simular to alerts or messenging and select that option and set ringer volume and or ringtone hope that helps you
Jul 06, 2009 | Cell Phones
Unlock zte c78
i have a zte c78 unlock it
Jun 15, 2009 | Motorola Mobility RAZR V3
Motorola U9 - irritating noise
Found it myself. I was looking in the settings for ring tones/alerts and all along this little feature was hiding in the Networks menu. It's a simple thing to have set on or off and for some reason after repair my phone was returned with this setting switched to on. It's an alert to let you know when there is no network coverage and the phone is searching. All well and good but very irritating if you live in a poor signal area!
Apr 28, 2009 | Motorola Mobility MOTO U9 Pink Cellular...
My razor can't connect to the network
Hi!
Please check that sim is seated properly.
Feb 04, 2009 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
