Question about Delta GR450 ShopMaster 8'' Variable Speed Grinder
Does the delta gr450 take a one inch thick wheel
  • 3 Answers
You can check the online parts manual
however it doesn't give the size of the wheel, only the part number of which there are two
23269 and 23270
Posted on Jan 04, 2010
Why does my delta portable thickness planer shut off after a few moments
Sounds like the thermistor is killing it. Probably the new brushes are generating too much heat. Did you put them in correctly, so the curved surface matches the armature sleeve?
Sep 17, 2014 | Delta 22-590 13-inch Portable Thickness...
Where to find tool manual for Delta 23 710 Wet/Dry Sharpening Center
delta machinery
4825 highway 45 north
jackson, tn 38305
(800) 223-7278
www.deltaportercable.com
porter cable
Sep 03, 2013 | Delta 23 710 1/5 Horsepower Wet/Dry...
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
28-276 Delta bandsaw blade keeps coming off?
Unplug the machine, gain access to the two wheels. On the back of the machine you should have a tilt adjustment knob. Manually turn the wheels in the direction of the cut and at the same turn adjust the tilt knob on the back of the machine. This should solve the problem.
Sep 27, 2010 | Delta 28 168 Bench Band Saw Blade 56 1/8...
I need an owners manual for delta gr450 8
Here's a link to download the pdf.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A15786.pdf
If it doesn't work, start here:
http://www.deltaportercable.com
Mar 02, 2010 | Delta Shopmaster 8" Bench Grinder
Removing wheels on delta gr450 grinder
They are usually left handed threads so they will self tighten when running. Try turnung then the ither way.
Sep 15, 2009 | Delta GR450 ShopMaster 8'' Variable Speed...
Delta 12 inch thickness planer blade change
Go to this link and at the bottom center of the page insert your model number. You will be able to download the manual for that machine.
Delta manual
If your question has been answered, or I fixed your problem, please take just a moment to rate this post...thanks!!
Mar 23, 2009 | Tools & Hardware - Others
Grinder won't stay running
The capacitor is easy to change and can be matched once you remove it by any electronics parts house.
Nov 24, 2008 | Delta 23 884 8 Inch Bench Grinder Wheel,...
Delta GR450 ShopMaster 8'' Variable Speed Grinder Logo
79 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
