Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
F1 appears both drawers are flashing and beeping can't turn off power (it turns off for a moment and then turn itself back on with F1 code, beeping and flashing) Unplugged it hoping it would reset, it did not.
  • jack7794 Dec 18, 2009
    I was not able to see what solution you offered, but had a service man come out and fix it.
    The problem was flooding of sensor beneath the bottom drawer.
    Diagnosis is if the outer sides of drawers are wet, then some contents stuck out too much and did not permit proper sealing.
    Pull out bottom drawer, push in the plastic square tabs on the side so that the drawer can glide forward and be fully pulled off the rails. Lift the drawer with all hoses still connected and set it on its side.
    You now have access to the bottom of the washer (which is probably flooded. It has a plastic housing in the rear covering the sensor. Lift it and mop up water until dry.
  • 30 Answers
F1 means that the flood sensor has been tripped. Remove the bottom draw and dry the water out. Mop the majority out and use a hair dryer to get it all nice and dry. This should clear the f1. There may be underlying issues of why the unit has leaked but see how you get on.
Posted on Dec 21, 2009
What could be the problem if F1 code and beeping in GE wall oven/
F1=Touch control pad and or Clock defective.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Jan 11, 2011 | Ovens
Machine powers on by itself both drawers.. with the error message
F1 can mean two things - depending on which drawer it is coming in.
It is a sign that the water is leaking from the drawers into the base of the housing and tripping the flood switch.
To fix this you will have to take the drawers out and dry out the flood switch at the base of the housing. Use towels and hair dryer. Most like the dishwasher detergent is foaming or the door seal is leaking or the outlet drain is cracked. Make sure the mains power is turned off when you are working on the dishwasher.
The other reason is if the thermal cutout is blown in the lower drawer that can cause the F1 to appear in top drawer. But if both drawers are flashing F1 then this is unlikely.
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to shut off dishwasher? F1 is flashing on control panel.
Hi now F1 mean that your machine has triggered the flood alarm. there are two reasons this happens-- 1st-- there is a leak on one or both of your drawers. they leak because you might have a hole in one of the hoses or your lid is not shutting properly etc. the 2nd reason is that some water or soap suds escaped from the overflow. now i would like you to turn the machine off at the wall and leave it off for a couple of days to dry it out. then turn it on and use the lower drawer for one cycle. if it does not go F1 then try the top drawer for one cycle and see how it goes. if it continues to flash F1 then reply back for further help. good luck.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 in F&P 2 drawer dishwasher
You will need to be a bit more specific when you say "no flood".
Are you having this F1 fault in one or both drawers?
What did the engineer do when he was there last time?
Does the F1 code flash with beeps?
What happens when you turn the mains power off and on after a short delay?
Please provide the actual model number of your fisher and paykel 2 drawer dishwasher.
May 19, 2010 | Fisher and Paykel Dishwashers
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Dec 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
330 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
