Question about Brother MFC-7820N Laser Printer
My wife tried to print on T-Shirt tranfers meant for ink-jet printers, and they melted onto the fuser roll, and it stinks. I need to remove the fuser assembly and clean it, but could use some instructions. Is there a repair manual or tech support instruction sheet available?
  • 532 Answers
This might help. I did the same thing with my laserjet printer.
Staples has laserjet cleaning sheets. I ran several sheets through the printer after I pulled most of the transfer paper out.
The sheets are one use sheets so, you will need a few.They are impregnated with cleaning fluid on textured paper.
These sheets clean the entire paper travel path.
Posted on Dec 12, 2009
How to fix error code c3102 konika minolta bhizub c754
Sir/Mam, Something is preventing one of the fuser (Hot Part) roller from turning had this happen at a school teacher melted a transparency in the fuser by using a ink jet printer type transparency on this model copier cost the school 2000 dollars. Anyway hope you did not melt a transparency any way check the fuser the hot part for paper that may have wrapped it self around the orange rollers in the Fuser (The hot part of the copier if so you need a new fuser or have a tech come out and see if he can remove it. IF you use any type of tool you can damage the roller and your copies and prints will have marks all over them. Trying to reset the code prior to verifying the motor can turn allows the possibility of burning the motor out and taking the control board that controls it now your talking 3 to 4 thousand dollars
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 11, 2015 | Minolta Office Equipment & Supplies
I dont have a ( black ) color even when i clean head and cartrige .. also i chang the tranfer wire .. please help me with that thank's
try to remove black cartrigde make sure ink is compatible to your printer then wipe gently wet cotton shirt or tissue in the film of cartridge after wipe out and clean the surface insert it try to print.
Dec 05, 2012 | Office Equipment & Supplies
Solutions for "engine fuser low
The "fuser" should heat-up to its operating temperature to "melt" the dry toner-ink onto the paper.
If it is not heating up, then each page you print and brush with your fingers will remove the toner.
So, replace the fuser, or get it professionally replaced.
May 15, 2011 | Samsung ML-3561N Laser Printer
An error jut appeared on my laser-jet 4200 saying 50.1 Fuser Error and asked that the printer be switched off and then on but the error is still there and i cannot print. What could be wrong and how can...
A laser printer works by putting the dry toner ink onto the paper, and then using heat, via the "fuser drum", to melt the ink into the paper, permanently bonding the ink to the paper.
So, a "fuser error" means that the fuser unit is not heating up to its "operating" range of temperatures.
Take the printer to a qualified technician, for trouble-shooting, and repair.
It might be cheaper to REPLACE the printer, rather than paying the technician to REPAIR the printer.
May 09, 2011 | Computers & Internet
Difference between electrostatic and inkjet printer
This sounds like a "homework" assignment.
An electrostatic printer puts electrical charges onto a drum.
Then, dry "powder" ink is put onto the drum.
The ink sticks only to the charged points.
A piece of paper is rolled against the drum.
The "fuser" heats the paper, and melts the ink into the paper, permanently "fixing" onto the paper.
An ink-jet printer shoots microscopic drops of wet, heated, ink onto the paper.
The ink dries into the paper.
Jan 27, 2011 | Nikon COOLPRINT Thermal Printer
Hp 4250 laser jet vertical streak ghost image
The problem you are having is caused by the fuser. The fuser is the part in the printer that heats up and basically melts ( fuses) the toner to the page. The fuser has a heat roller that is coated with teflon, your fuser coating has worn off in spots so the toner is sticking to the roller and causing the ghost image. You will need to order a replacement fuser. You can do a search on Google to find a replacement, the parts number is RM1-1082.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 04, 2010 | HP LaserJet 4250 Printer
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
We keep getting the following message - restart printer reseat fuser
The "fuser" uses heat to melt the toner-ink onto the paper, to "fix" the ink to the paper.
Open the printer, remove the cartridge, and make sure that the fuser is _exactly_ "seated" into its socket. Replace the cartridge, and try againn.
Otherwise, take the printer to a qualified technician.
Jan 14, 2010 | Dell 3010cn Laser Printer
Xerox m 24 creasing paperon A3 prints
check the pressure of the fuser adjustment
Oct 23, 2009 | Xerox WorkCentre M-24 Color Copier
Replacing fuser roll in hp4200n
No sorry you can only get the fuser assembly. You should be able to get hold of a refurbished one to keep costs down though.
Mar 23, 2009 | HP LaserJet 4200n Printer
Brother MFC-7820N Laser Printer Logo
133 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
