Question about Air Tools & Compressors
I have a Husky Pro 30 gal a/c. How do I adjust
I have a Husky Pro 30 gal a/c. How do I adjust the tank holding pressure?
  • compman66
    compman66 May 11, 2010
    what are you trying to adjust it to? and from what? are you wanting to go higher that it was when new?
  • 530 Answers
The adjustment for "Cut-In" and "Cut Out" can be found under the pressure switch cover, if available. Some switches are sealed to prevent tampering that might compromise safety.
If you remove the cover you will see the four electrical connections and one or two screws with springs under them. Most times if the adjustments are accessible you will find a set of instructions under the switch cover. One screw will adjust both the "Cut-In/Cut-Out" pressure and one to adjust the "Cut-Out" pressure only.
However you need to remember some important issues regarding these adjustments. The first is that the "Cut-In/Cut-Out" pressure is set at the factory and is set there for a reason. The only reason to change these is because over time the adjustments can change or you are installing a new switch. The other thing to remember is that the safety relief valve is set just above the "Cut-Out" psi. So any meaningful increase will only trigger the safety valve.
If you need to readjust your compressor back to factory settings make sure you do it with small adjustments. 1/4 to 1/2 turn of the screws. Run the compressor and check both the "Cut-In" and "Cut Out" psi setting before making another adjustment.
Hope this helps, good luck and please be careful.
Posted on Dec 14, 2009
How to connect two 1000 gal lp tanks together
Assuming that you want only one tank to run out at a time, you will need to set each at a different supply pressure, then Tee them together on the delivery side of the regulators. You will need pressure-holding regulators. Pressure-relieving type will not work unless you add a one-way backflow prevention valve after the regulator in the branch that is set to lower pressure.
May 27, 2014 | All-Pro Propane Garage Shop Heaters - All...
Husky air compressor repair
Are you meaning that you cannot adjust the regulator to change the pressure output?
Jun 01, 2013 | Husky Factory Reconditioned Electric Air...
Portable oiless compressor wont pressurize
If there is pressure at the pump, either:
1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Got a Husky 6 gal pancake, 1.5hp. motor runs- no air pressure ??
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Dent in air compressor tank
was the tank creased? you can take it to a compressed gas refiller and ask them to pressure test the tank.
May 25, 2009 | Air Tools & Compressors
My husky pro vt631402aj verticle compressor won't stay running when compression rises
Hello,check to see if it cuts off at the same psi each time.If so,youneed to adjust the pressure switch to the tank to the max & adjust the pressure to the tool you want to run with the pressure out kob.Hope this helps
Dec 29, 2008 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Air Tools & Compressors Logo
367 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
