Question about Compaq FP 7317 17" LCD Monitor
It comes on but flashes off then waits a few seconds and comes on then it flashes off and continues in this fasion
  • 1,684 Answers
You have a monitor with a power supply that has failed. The heat buildup in the case has caused parts called capacitors to blow out. Go to our web site at:
www.ccl-la.com/badcaps.htm These pictures show what capacitors that have blown look like. If you can solder then you should be able to do the repair. Open the back and look at your power supply. Replace all capacitors that have even the slightest bulge on top. Be sure to use high temp caps they will be marked 105c. Also be sure to install the new caps with the polarity stripe on the side going the same direction as the old ones come out. The values you will need to get will be marked on the sides of the bad one but will be like 220uf, 470uf or 1000uf and then a voltage rating. If you don't want to do the repair yourself we do offer a repair service for $30 plus return shipping. Let us know if you have any questions, our contact info is below.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
buddy@ccl-la.com
Posted on Dec 12, 2009
SOURCE:
I got a xbox wheel for racing games and iit wont connect to my xbox
Matthew Sanges "Are you pressing the sync button on the console as well as on the steering wheel to make them acknowledge each other?"
Yes. This is all you have to do. The "sync buttons" are the two arrows.
If you buy an extra controller, it is the same.
Jul 04, 2014 | Microsoft Xbox 360 Console
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
4x4 light flashes six times every two minutes or so and 4x4 will not engage. Can you help me?
try shifting it to neutral and wait a few seconds,if it still flashes try shifting it to drive and wait a few seconds,then reverse.if it still doesnt lock in then move the vehicle a few feet either forward or reverse,worst case the electric motor on the transfercase is bad
Dec 26, 2009 | 1995 Ford Ranger Supercab
My kodak z612 only flashes once in awhile
The flash has to "charge" up a high-voltage capacitor in order to work.
As a test: try a few flash shots, but wait ten seconds between shots. It should flash 100% of the time. If not, use new Alakaline batteries and try the test again.
If all works well, see how many you can "flash" while waiting only 2 seconds... some may work, others not. You will then get a fell of how many seconds you have top wait between flash shots.
Also, use flash for subjects nearby (up to 12 feet) ... no flash beyond that. Increase the ISO setting HIGHER (3200?) so that the flash doesn't work so hard.
Results? Use fully-charged Li-Ion or alkaline batts when you need to use the flash.
Sep 19, 2009 | Kodak EasyShare Z612 Digital Camera
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
CANT CONNECT BLUETOOTH TO MY PHONE
  • Start w/ power off (Best way to make sure you are off is to plug the headset into the charger for 1 minute, then unplug & wait 10 seconds before continuing.)
  • Press & hold MFB. DO NOT RELEASE YET.
  • light will flash quickly a few times to indicate power on. (Still holding MFB)
  • After a few more seconds of holding the MFB the light should glow steady.
  • Once the light is on steady you may release the MFB and pair with your phone.
good luck
Jan 02, 2008 | Motorola Mobility RAZR V3
Compaq FP 7317 17" LCD Monitor Logo
129 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
