Question about Electrovaya Scribbler 2000 (SC 2000) Tablet PC
After runnig on battery power it powers off
After runnig on battery power for 20 minutes it powers off instantly without warning. It will not start again until the AC power uint is pluged in.
Will run on AC power without a problem
Thanks
  • 244 Answers
Obviously its a battery problem
Usually happens on old batteries.
A new replacement will fix this problem.
Usually a healthy baterry should last between 1 to 2 hours...some models even give you 4 hours working time.
Don't forget to rate this answer if it helps.
Posted on Dec 12, 2009
SOURCE:
How do I factory reset a Ematic EGQ327M tablet without a password
FixYa
Ematic Eb104 eBook Reader
Question about Ematic Eb104 eBook Reader
ematic 7" QUAD CORE TABLET EGQ307 FORGOT PASSWORD HOW TO RESET IT CANT GET ON ANYTHING WITHOUT IT
by sharhonda cox on Jan 8, 2014
Add Comment · Flag · Share
April Argo
Level 1 New Friend · Contributor
Andrew Jones answer was correct...
Helpful 0 Not Helpful ·Add Comment ·Flag
M Asish
Level 2 MVP · Expert
Try resetting it by holding down the power button for 10 seconds.that would shut it down. Restart then try logging in. Try to factory reset using the combination buttons as listed below
look for a tiny reset pinhole along the case it may reset the tablet too All RESETTING Ways Below Holding Down Certain Sequence of Keys or Buttons will put Most Tablets or Android Phones in Service mode to Factory Restore to New.
Hold Vol + & Power 20 sec
Hold Vol - & Power 20 sec
Hold Vol + - & Power 20 sec
Hold Home & Power 20 Sec
Hold Vol + & home & Power 20 sec
Hold vol - & home & power 20 sec
Hold Vol + - & Home & Power 20
Aug 04, 2018 | Tablets & eReaders
After fully charged battery power lasted about 20 minutes.
Since it's brand new, return it. You didn't say what type of tablet it is, but they should last for many hours on a charge.
Oct 02, 2015 | Tablets & eReaders
My Ipad is locking on me and I dont understand why nor do I know how to fix it.
The Line on the screen indicates a damaged screen or faulty screen connection to the main circuit board.
Is the battery status low or decreasing very rapidly (activate percentage display for the battery) then it could be your battery is worn out. It can cause the iPad to shut off or reboot when the battery can't deliver the required power anymore. Like when you run a power intensive task the power drain is too much for the battery and it can't keep the required voltage.
Jul 31, 2017 | Apple iPad Tablets & eReaders
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
My sons rca 10.1 tablet wont power up.....right before this happened it was froze on the start up screen and wouldnt power off. I let the power run down hoping then I could charge it and it would power up...
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Jan 19, 2015 | Tablets & eReaders
My i pad will not turn on
First steps: Make sure you're up to date
  1. Verify you have installed the latest version of iTunes.
  2. Verify that you are connecting iPad to your computer using a USB 2.0 port.
  3. Make sure your iPad software is up to date: With your iPad connected to your computer, click "Check for Update" in the Summary section of iTunes.
  4. Charge your battery: Using the USB power adapter that came with iPad, charge iPad for at least 20 minutes before further troubleshooting. If necessary, refer to "Charging the Battery"
Jul 07, 2014 | Apple iPad Tablets & eReaders
Netbook turns off instantly when power cord plugged in - even when not plugged into power outlet!
Have you tried a different adaptor or power outlet other than that the dc jack on the notepad may need replaced
May 08, 2013 | Gigabyte Atom Series Netbook: Q2005 -...
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Dec 09, 2011 | Samsung Galaxy Tab Tablet PC
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Electrovaya Scribbler 2000 (SC 2000) Tablet PC Logo
108 people viewed this question
Top Electrovaya Tablets & eReaders Experts
Marvin
Marvin
Are you an Electrovaya Tablet and eReader Expert? Answer questions, earn points and help others
