Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Can not get the printer heads cleaned. Have installed new cartriges and tried to clean many times---Epson 870 printer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The printer head cleaning requires Isopropanol Cleaning Solvent and a piece of cloth – 10cm long by 1.5cm wide by 2mm thick. This technique is excellent for softening dried ink under the print head that can cause blockages. Please follow the step by step procedure as given below:
Switch off the Printer.
Switch the Blue lever on the right hand side of the printer to the + position, this raises the ink head.
Soak the cloth in Isopropanol Cleaning Solvent.
Place the soaked cloth on the left hand side of the printer so it lies on the bottom where there is a square of felt-like material. This position is where you normally change your ink cartridges.
Press the yellow so the printer head moves over the soaked cloth
Switch the blue lever at the back to the 0 position so the ink head lowers down onto the cloth.
Preferably, leave the printer in this state overnight.
In the morning, raise the head (put the blue lever in the + position) and move it to the right of the printer by pressing the yellow button.
Remove the cloth. And return the purple lever to the 0 position.
Turn the printer on and perform a nozzle check.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 13, 2009
SOURCE:
I have epson r230. In light magenta vertical lines appear, i run clean print head many times, but not resolved, in skintone green color appear. wht to do
In these situation you can try these procedure.
Take a empty cis . pour it with amonia solution ( water40% + amonia60%). set th CIS and run head clean. 2/3 times. put off Cis. set original cartrige/ CIS with ink. Run head clean.1/2 times. print a nozzle cheak. I Think you may relive from your problem.
Thank you.
Jun 28, 2011 | Epson Stylus Photo R220 InkJet Printer
Epson C63 will not print despite having changed all the inks. It tries but the paper is blank
I think there are 2 causes epson c 63 printer not print problem.
First one is: Your ink cartrige are not install properly.
Solution: Try to install ink cartrige properly, in this time please clean ink cartrige chip as well as connector.
Secoundly: printer main board problem. Print data does not pass through main board.
Solution: Please replace new one.
I think you will relive from the problem.
Thank yoou.
Feb 28, 2011 | Epson Stylus C63 InkJet Printer
Ink light on stays on despite inserting new cartridges
try cleaning the contacts (golden patches) on the cartrige and on the print head. also try to do a 'print head clean' from the service / maintenance menu
May 10, 2010 | Epson Stylus DX4850 All-In-One InkJet...
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
My Epson stylus C86 will not print even though I have put 4 new cartriges in and cleaned the heads
Check.......removable tabs removed, cartridges installed [they Click when pushed down]. Did you get a Clear test pattern? If all the above have been done and you still have a problem, it's time to call Epson tech support
Jun 29, 2009 | Epson Stylus C86 InkJet Printer
Checking ink levels how do i do this
Install the status monitor, it's usually on the epson cd it comes with
but if you don't have it go HERE
Mar 21, 2009 | Epson Stylus Photo 870 InkJet Printer
Ink cartrige error(epson 9800)
I would try getting new EPSON brand cartridges for it and trying after that ...
Jan 19, 2009 | Epson Stylus Pro 9800 InkJet Printer
Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Apr 06, 2008 | Epson Stylus R265 InkJet Photo Printer
Cartrige refilled reset but no colourprinting epson stylus c66
Clean the print head/Control panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Nov 02, 2007 | Epson Stylus C66 Inkjet Printer
Epson 1280 red lines on photo
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
