Question about Kenmore Dryers
Knocking sound in back of dryer - Kenmore Dryers
  • Kenmore Master
  • 2,696 Answers
If the lint filter is on top of dryer then your blower wheel will be in the back of dryer,this could be the problem,the wheel could of cracked or there could be lint stuck on the arm blades of the wheel making it unbalanced as it spins.you'll need to take the duct off to get at it and spin it by hand to see if it feels loose or check for cracks,while you have the duct off clean it out and vac the inside of dryer,you should clean the dryer out at least once a year so you don't have a fire more so if it's gas.it could also be a roller that's bad,the drum rides on two rollers that are on the back wall,next time send model number so i can look up your machine,the number is located on the door jam,open the door and look around the opening where you put clothes into dryer,hope this helps
Posted on Dec 12, 2009
My hotpoint TVF760 dryer is making a knocking sound
You might have a bearing out.. Possibly try in take back off and video the dryer running so we can see.. Be careful.
Mar 19, 2013 | Dryers
MY DRYER HAS STARTED TO HAVE A KNOCKING SOUND ON ALL SETTINGS PERIODICALLY DURING THE DRYING CYCLE. IT SOUNDS JUST LIKE SOMEONE KNOCKING ON FRONT DOOR OR LIKE A SHOE BANGING AROUND IN DRYER. MAYBE NOT...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 15, 2011 | Fisher and Paykel DEGX2 Dryer
Dryer is knocking,on left rear side you can feel the knocking and when you press it knocks louder
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our dryer is making a terrable sqeeking sound from the back of the unit ????
heatman101
Asker
Nov 22, 2010 | Frigidaire Dryers
My Maytag dryer has a squeeling sound like a small pig while holding his back legs. It is drying good but making that sound. Maybe a baring?
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 14, 2010 | Maytag Dryers
The drum is making a resonating sound when turning.
heatman101
May 23, 2010 | Bosch Axxis WTA 4107 Electric Dryer
Dryer making knocking sound
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 13, 2009 | Kenmore 62602 Electric Dryer
My LG DLE2514W electric dryer starting making a squeaking noise at the end of a drying cycle last night. After letting it sit for over an hour, started the dryer back up and the squeaking noise came back...
heatman101
vciku
Jun 29, 2009 | LG DLE2514 Electric Dryer
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
60 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
