The arm no longers travels in the downward direction enough to make contact with the record. After several cycles, the arm is not traveling as far as it was initially (there is clearly 1/8'' between the record and the needle. Is this adjustable? Thanks, Gary
  • 478 Answers
Yes it is gary depending on the turntable some are not adjustable at all but I' going to give you a url to help you with your quest
http://www.turntablebasics.com/align.html
Posted on Dec 12, 2009
Tone arm sometimes does not travel far enough to engage record grooves
Are you playing 33.3, 45 or 78???? The settings have to match the disc speed!
Dec 02, 2017 | Audio Players & Recorders
My rockola 424 turns but wont play
Are all the gears at the base of the gripper arm free to travel their full distance?
Aug 20, 2014 | Audio Players & Recorders
Chamberlain 1/2 hp opener stops intermittently during travel.
could be that the remote operation or cycle operation needs reprogramming as it indicates that the program has a corruption in it and the action is lost by that corruption
follow the user manual and do the reprogram sequence
Jul 09, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
My john deere traveling sprinker is traveling backwards. Is there a setting I can change to make it go forward?
Its direction of travel is dependent on which way the spray arm spins. Was the arm bent in someway that might make it spin the wrong direction? The arm nozzles are pointed the wrong direction. If there is an adjustment that's where you need to change its direction of travel.
Jun 08, 2011 | John Deere Gilmour Traveling Sprinkler -...
HBW077 Craftsman: door travels downward only 10"
Sounds like you have a bad RPM sensor board. This is a small printed circuit board just in front of the motor. It's job is to reverse the door when it hits an obstacle but will act as you describe when they go bad. The part number is 41C4398A and is available at Sears or any good door service company.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Shimano TX-31 is not lined up correctly. When I shift into 7th the chain comes off because the Derailer goes beyond the 7 sprocket. How do I adjust this? It is also causes a clicking sound when in 1...
There are two screws that limit how far the derailer travels in both directions. Yours is apparently traveling to far out, and not far enough in. See the diagram at the link below. The two screws are identified by number 3. You will need to adjust both of them. With the chain on an intermediate gear, try turning one of them them 1/4 turn, then check the result. You'll soon get it right. Good luck. If you found this useful, please vote
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/RD/EV-RD-TX31-2753B_v1_m56577569830637983.pdf
Sep 01, 2010 | Shimano Cycling
IT turntable will not play the entire song on 45 rpm for converting to MP3. The stylus automatically lifts up from the record before the entire song has played.
If you're mechanically inclined and can open up the case, then look inside the mechanism, oil it, and put the case back together again, this is what may be happening.
There's a mechanical sensor/actuator inside the turntable that gets pushed by the pick up arm as it travels and nears the center of the turntable. Chances are it may have been set to actuate too early, or it may need oiling, if this is an old turntable that's been lying around unused for several years.
This sensor usually consists of a thin metal plate that can be bent manualy or with a pair of plyers.
Remove the stylus or pickup head, or protect it from damage by using a probable built-in cover. Diassemble the turntable so that the flat surface holding the turning plate can be separated from the case.
Set the disassembled turntable with one edge over some piece of furniture or anything to prop it up while you watch what happens as you move the arm towards the center. You may need to recruit a helper who will turn the plate slowly and move the arm inwards while you watch from underneath.
You will eventually see some part making contact with another, which in turns engages the mechanism that lifts the arm.
Bend this tang just enough to allow the arm to travel further towards the center the necessary distance as to completely play the 45s.
Reassamble the case and try a few records. This will be a trial and error process. Keep making adjustments as needed.
If all of them play to your satisfaction, then you may tighten the screws securely.
Aug 24, 2009 | Audio Players & Recorders
Wipers on 2000 Jeep Cherokee travel too far
hello, this sounds like your wiper transmission got out of alignment possibly due to ice on windsheild.don't really know.short of replacing you could loosen the nut under the cover and move wiper arm back possibly.
Jan 25, 2009 | 2000 Jeep Grand Cherokee
Garage door won't close
your door travel screw is set to go too far on the downward travel. you need to set the down travel. It is set to go too far down. find the screw adjustment on the unit that says close and back off the screw a full turn until door stops short of floor. then start turning screw other way until door just touvhes floor.
Feb 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
20 people viewed this question
k24674
jasbo
jasbo
