Question about Coby MP-C7085 MP3 Player
My mp3 wont sync!
My computer will not say my coby mp-600 is connected but the mp3 player it's self says it is it does charge but it will not let me sync songs to it because the computer says
"Connect a supported deice to your computer" It also says "Device is currently not plugged in"
HELP!
    Scholar:
  • 121 Answers
Take back to place where it was bought and request a replacement. If your computer doesn't see it when it's connected, then there is something faulty with the device.
Posted on Dec 15, 2009
SOURCE:
My coby mp705 wont turn on but when i plug it to my computer it works.. what kind of assistance shall i do to make my coby back to normal? any kind of answer would be wonderful
sounds like the battery is the problem if it wont start wothout a power source
Check the system requirements for the MP3 player.
Most Coby players require Windows XP or higher and at least 1 GB of RAM to function correctly.
Check your Coby owner's manual to ensure that your machine meets all the required specifications before proceeding.
Charge the MP3 player fully.
Often, a player will act unexpectedly if it has a low charge.
A charge can also help reset the MP3 player if it has frozen or locked up.
Once the player has finished charging to 100%, see if the problem persists.
Re-sync your player.
Plug the MP3 player back in to the computer and then remove all the files.
If you have not done so already, make sure they are backed up to your hard drive.
Unplug your MP3 player and then re-load all of your files.
Check for corrupted and wrong format files.
Most Coby MP3 players only play back MP3 files, and will perform unexpected operations
if files of other formats are uploaded to the device.
Go through your uploaded files and check the extensions.
Anything that does not say ".mp3" or is not listed in your owner's manual needs to be deleted from the device.
hope this helps
Sep 30, 2012 | Coby MP-705 Digital Media Player
My coby mp touch isnt connecting to my pc
Turn on MP3 player
Go to Setup > System > USB MODE
Put the USB MODE to MSC
Reconnect to the computer
Your computer should then recognize the MP3 player.
Apr 12, 2010 | Coby MP-705 Digital Media Player
Coby 610-2g mp3 player wont read or turn on
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will let your computer see it again & turn on etc.
Please follow these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Mar 20, 2010 | Coby MP-610 MP3 Player
I WONT TURN ON
Sometimes unplugging your MP3 player will disrupt it's file system if 'Safely Remove Hardware' or 'Eject' is not used. Following these instructions for fixing your Coby Mp-610 MP3 Player will fix your MP3 players file system.
Feb 06, 2010 | Coby MP-610 MP3 Player
How do I recharge Coby MP3 player? I plugged into USB port for over an hour but it stopped playing after about 20 minutes. Do I need to replace the battery or charge it longer or both? Thanks. Claudia
Coby MPC7085 requires a 12 hours charge when used for the first time.
Always use a direct connection to the computer when charging with the USB cable: a hub or cardreader should be self-powered.
See page 12 of the manual:
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
Sep 28, 2009 | Coby MP-C7085 MP3 Player
Coby 2g mp3 wont charge
go to.
setup
power
sleep
and select off
I you hope to have helped
Dec 28, 2008 | Coby MP-C7085 MP3 Player
Coby mp4 player mp-c79095
I didn't have a problem accessing the flash memory of my Coby mp4 until I upgraded to Media Player 11. Now it recognizes the coby for what it is, but I can't explore the flash memory like I used to. It used to recognize it as another drive, now it shows up as a portable media device. Do I have to go back to MP10 to get it back or is there another way?
Oct 04, 2008 | Coby MP-C7085 MP3 Player
Coby MP-C7095
To charge the mp3 all you do is plug in your mp3 to the usb port on your computer... Then to download music, once you put on your mp3 to the computer it should pop up and then you can either go to my comp and choose your mp3 and drag files into it or you can go to real player, window's media player and sync music through one of those programs
Apr 12, 2008 | Coby MP-C7085 MP3 Player
Coby mp-c7095 mp3 player will not charge was working but not now
I bought a Coby mp-c7095 and could not get it to turnon. I charged the battery for more then 24 hours and it still would not turnon.
The problem was easily fixed. The red battery wire was pinched during assembly and shorted to the back cover. I put a small piece of tape over the bare wire and carefully reassembled the unit. Now it works great!
Jan 25, 2008 | Coby MP-C7097 MP3 Player
Coby MP-C7085 MP3 Player Logo
130 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Joe Negus
Joe Negus
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
