Onkyo 501 Onkyo Receiver no sound out of right
Onkyo 501 Onkyo Receiver no sound out of right channel. Wire and speaker are good.
  • 478 Answers
If you are good at tinkering then you can pulol the top of the receiver and check the fuses on the board to make sure that they did not blow if not then it would be wise to take it to a repair shop to have your receiver checked out and serviced
Posted on Dec 12, 2009
How can I fix my amplifier?
Swap input cables to the left side to verify both sides are clean. The power module for the right channel is probably toast. Or the protection relay for the right channel is very resistive.
The power module does not exist on the internet.
Go to Ebay, find a 100% seller, buy a M-501 for a good price, use your M-501 for spare parts.
Jun 12, 2014 | Onkyo M-501 Amplifier
10 years and first problem to repair. When you turn on and select DVD or any other selection a very loud cracking noise comes through right speaker only. So loud (with volume tuned off too) that I fear...
I think your receiver is damaged.
Try this.
Mark the speaker wires on the back of the receiver. label the speaker connected to the left channel "Left" and the speaker connected the the right channel "Right"
Also pay attention to the polarity (positive an negative) making some type of marking on your speaker wire so you can reconnect them correctly.
Disconnect both left and right speakers.
Connect the speaker wire that is labeled "Right" to the receiver's left speaker connections only then turn your receiver on.
IF the loud noise comes back, this speaker is damaged. I am guessing that the speaker is fine.
Now connect the speaker that was labeled "Left" to the receiver's right speaker connections and turn the receiver on.
IF the loud noise comes back like it did before but now playing through the "good" speaker there is a problem with your receiver.
If so, your receiver is 10 years old. Isn't it time for an upgrade? Try ebay for good used equipment deals.
May 01, 2014 | Onkyo TX-DS787 Receiver
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
Onkyo TX-SR605. Low or no sound output
Does any good sound come through headphones, if you plug any in?
Apr 24, 2017 | Onkyo TX-SR605 Receiver
One speaker only works in Mono mode
I would be checking the set up mode , you might have it set to left or right channel only , but in mono mode both speakers will come on through one channel
May 25, 2009 | Onkyo TX-SR875 Receiver
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Rear left channel not working on Onkyo NR801
Sounds as if it's time for a shop visit, unless you want to try this yourself. The panel connection on the rear of the receiver, or the protection relay have apparently come loose from the circuit board. It happens sometimes when stress causes the cabling to pull on the back of the unit..accordianman
Feb 16, 2007 | Onkyo TX-NR801 Receiver
364 people viewed this question
 Grubhead
Grubhead
Steve Allison
Steve Allison
