Question about Samsung HT-Z310T Theater System
No sound is produced when using digital optical cable i have to use rca jacks with the yellow one unplugged
    Brigadier General:
  • 8,546 Answers
What are you connecting to what? It soundslike we have an unnamed external device in the mix here. Start there.
Posted on Dec 12, 2009
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
How do I connect a sound bar to my Panasonic TX-50A300B I want to use an optical cable as ear phone jack does not produce a decent level
If your TV has an optical port on the back, you simply get an optical cable long enough to connect the two. On your TV sound setup screen you'll have to select optical out so the sound from the TV will be switched from the RCA jacks to the optical out port.
Nov 21, 2015 | Panasonic Televison & Video
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
How to connect samsung ps50c55og to sony dav s500 home theatre system
You need a set of normal rca cables (red.yellow,white) and another single rca cable..
OPTION 1 :If you have a digital satellite receiver, Connect the 3 colour cables to the corresponding colour jacks on VIDEO 2 of your dvd player to corresponding colour jacks on the VIDEO OUT Of your digital satellite receiver...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 2 STRAIGHT TO TV: connect the 3 colour cables directly to the corresponding colour jacks on the SIDE of the tv...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 3 IF YOUR PLAYER HAS AN OPTICAL INPUT: if this is the case you can just connect a single optical cable to the optical ports on your player and tv and this will enable the sound from your tv to play through your dvd player as well
Feb 12, 2013 | Audio Players & Recorders
Sound does not work for tv shows. It has no sound issues with xbox or playing dvds. I've changed about every setting I can think of.
what are your inputs for the tv? is it from a cable box and connects with a coax cable. ? if you are using hdmi make sure you select auto out as digital from cable box and input from the tv as that audio in the mnu settings also. if you are using old school rca jacks (red yellow white make sure there in tight. if you are using component red blue green then you still need an audio either optical or the rca red and yellow from whatever your connecting to your tv. let me know if this solves your problem
Mar 17, 2011 | Vizio L32 32 in. LCD HDTV
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
No sound!
There are Yellow Video jacks on the DVD and TV for Video.
There are Red and White RCA Jacks for Sound.
Or
Fiber Optic Toslink for sound.
Are you using the red and white cables?
AL
Apr 26, 2009 | Panasonic DVD-RV27 DVD Player
No color and no audio
yes , this is why , on your dvd there is a "yellow for video" output on it ,and then there is a "red output jack for right audio"
and then there is a "white output jack for left audio" does your tv have these inputs?
the blue , green and red "RCA JACKS" are called " composite video" which seperates the colors of given video
the red and white RCA jacks are for right and left audio and are required when using composite or the yellow video jack
there is also a "s-video" connection that is one cable but seperates the colors for better picture quality ( dvd player only)( vcr and tuner do not work with this)
then there is a optical or coax digital connection for a reciever that decodes the connections audio digital signals for dolby digital surround sound
Jan 08, 2009 | GoVideo Go Video DVD/VCR Combo
Surround help
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
Jun 11, 2007 | RCA RT2390 System
Samsung HT-Z310T Theater System Logo
115 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
