Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
MOTHERBOARD PROBLEM HELP....THIS IS MY 3RD POST ABOUT THE
MOTHERBOARD PROBLEM..THIS IS MY 3RD POST ABOUT THE PROBLEM I ENCOUNTERD. IS THERE ANY ONE WHOSE BETTER COULD HELP ME? PLEASEEE....
first of all my mother board problem is BIOS CHECKSUM ERROR,KEYBOARD ERROR or NO KEYBOARD PRESENT (which is it has a keyboard and good) ,so u cant press the DEL or F1..
i tried to chnge my cmos battery into a NEW CMOS BATTERY that i brought, but still it doesnt fix the problem..
so i had to UPDATE my BIOS, booting in a FLOPPY DRIVE using my BOOTDISK.. while im doing these i got the problem of DISKBOOT FAILURE,INSERT SYSTEM DISK AND PRESS ENTER....
HOW TO FIX THESE.? HELPPPPP....
  • 488 Answers
You have a corrupted bios file or files. This is what the checksum means. You need to download the correct bios onto a floppy disk. That floppy disk needs to formatted as a system / startup disk BEFORE you copy the bios files to it. Then put the floppy into your floppy drive, turn the pc on and try to get into the bios screens. If the keyboard error is preventing this, go to the mainboard manufacturers website and check the correct manual for the board looking for the procedure to recover from a bios failure. If this board if no older then 5 yrs, it should have this feature. Follow the recovery procedure to rewrite your bios. When that is fixed, undertake the bios update procedure. ONLY do this if you fully understand and accept the risks otherwise, take it to your local professional. If your board does not have the recovery feature, replace it !!unless you are able to replace the CMOS chip with one which has the correct bios burnt onto it. As most modern boards have CMOS chips glued and soldered to the board, this may not be an option..If the bios chip is socketed, contact your local computer shop, or the boards manufacturer to request a replacement. Your issues all arise from your bios issues so fix that and all should be well..
Posted on Dec 12, 2009
I'm getting a POST error
Don't format the problem is in BIOS. Try setting defaults.
Nov 20, 2012 | Biostar A780L3G Motherboard
I945C-M7B I want mother board drivers plz help me.i havent Drivers Cd, if u can post drivers CD.u can post this address., No,92, 3rd lane.Walau waththa, Darmarama...
This link should have EVERYTHING you need. Most, if not all of the contents of the drivers disc are on this page.
Please be sure to click on the correct Windows version in the box where it says Select an Operating System & click on DRIVERS in the box next to it.
I would suggest downloading all these drivers into a single folder & burn that folder to a disc. That way, you have your own backup copy of the driver disc just in case you'll need it again in the future.
Aug 12, 2011 | Intel D102GGC2 Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
What sound card is compatible with my asus p5vd2-vm se im going to buy a altec lansing 6 channel speeaker pls. help
Your ASUS motherboard model has on-board sound. You are asking what 3rd party card to install?
Your motherboard supports:
PCI
PCIe x1
PCIe x16
A 3rd party sound card of your choosing that will fit in one of these vacant slots will do nicely.
Jan 02, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
16-bit ms-dos sub system error while runing graphics programs on ntvdm cpu on amd athlyon processorTurbo c++The NTVDM CPU has encounterd an illegal instructionCS:d3e8 IPc180 OP:ff ff ff ff ff ff
HI,
Navigate to updatemgr.exe in C:\Programs\Common Files. Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old, save the changes and click on OK. RESTART your computer and the problem should now be solved.
Please post back if you need anymore assistance.
Nov 09, 2009 | HP Computers & Internet
Asus P6T Deluxe motherboard won't post with 3rd RAM DIMM
that port is bad. If all three is known working the only explanation is that its a bad ram slot
Mar 29, 2009 | Computers & Internet
While upgrading my Noka N72 cell phone's firmware using usb cable software encounterd an error and got hanged and ever since my phone would not switch on.Any workaround while phone being switched off?
No known workaround on this really. But you can bring phone to service technician and have it resetted in there. They will upgrade firmware as well if phone is still working and revivable.
Bad news is, just like on a PC if it gets interrupted in the middle of a firmware upgrade (BIOS) it could cause the motherboard to crash and render it unusable.
Thanks and good luck!
Jan 17, 2009 | Lands Phones
Need help with playstation 3
i have encounterd myself and with many other people as i told others u haffto waite atlese todays try it every day for 20 mins if it dosent work call sony and they will help u for a fact and if they sey they cant if u have insurance they will come and pick up the ps3 by it self and give u a new 1 but same wires and cobtrollers. this is what happend 2 me once on my first ps3 now im on my 3rd. Hoped i helped
Dec 10, 2008 | Electronic Arts James Bond 007: Everything...
C1 led post code
try changing your RAM with new one
Nov 08, 2007 | EliteGroup ECS P4M800-M Socket...
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
219 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
