Question about Frigidaire Kitchen Ranges
Where is the fuse box on the frigidaire
    Problem Solver:
  • 12 Answers
They have a fuseable lynk not a fuse box
Posted on Dec 12, 2009
Frigidaire dryer dries for a few seconds then stops and lights blink.
Hi laylabetes - Answering your question, there isn't a way to actually CLEAN the control panel. Depending on an actual diagnose from a professional, the part would need replacing or if possible repair. However, if your model is electric, turns and there is no heat, it could possibly be a blown fuse. There are two house fuses that supply voltage to your dryer circuit in your fuse box. If one of the two is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. Please feel free to reconnect if this does not resolve your issue - Best, Chris
Jul 01, 2013 | Frigidaire Dryers
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dyer not run but have power
If it is an electric dryer and you are on a fuse box 220 line. Replace fuse, or check to see if pop out fuse is blown? Replace fuse or reset circuit breaker.
Apr 02, 2013 | Frigidaire Dryers
Frigidaire dishwasher stuck on heat dry
That happened to me also. The button dance did not work for me. I turned the switch on the fuse box off and waited for two minutes. When I turned the switch to fuse box on again my son two light were blinking and I told him to press the start button on the washer and it worked.
May 14, 2012 | Frigidaire 24 in. FDB635RF Built-in...
Just got electric dryer #FAQE7011LW0 dryer will not heat manual says check fuses but does not say where they are located
The fuse they are refering to is the fuse/circuit breaker for your house wiring in your house fuse box/breaker panel
Sep 18, 2011 | Frigidaire Dryers
Where is the house fuse located on the dryer
No fuse in dryer, the fuse or circuit breaker is in your house main fuse box.Hope this helped.
May 29, 2011 | Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire Affinity dryer stopped working after less than 2 years. No lights, nothing. I checked our fuse box and everything is fine. Is there a fuse in the dryer that needs to be replaced or reset?
there is a couple of thermal fuses that you can check inside the dryer chances are it is the one that is located one the back wall behind the drum
Sep 23, 2009 | Frigidaire Dryers
Where can I locate the blown fuse/s of a frigidaire dryer?
There are no user servicable fuses in the machine, I believe they are talking about your breaker box.
A 220 dryer requires two 110 volt circuits to run the 220 volt heater
The motor and control circuits only require 110 and are run from only one of these two lines. If the other line blows the dryer will still run but there will be no heat.
Good Luck
Quentin
Jul 06, 2009 | Frigidaire FEX831CS Top Load Stacked...
My Dryer won't get hot
try doing the following checks--
  • Check for proper air flow
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the heating element
If you need the manual check the following link.choose the manual for the appropriate model.
http://www.retrevo.com/samples/Frigidaire-Dryer-manuals.html
Dec 11, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Kitchen Ranges Logo
369 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
