Question about Maytag Neptune MAH5500B Front Load Washer
Why does my machine display read nf - Maytag Neptune MAH5500B Front Load Washer
    President:
  • 1,891 Answers
I belive that N F is no fill . ck your hose screens and make sure there clean.. ck hoses that the let water through properly . no kinks . if these do not correct problem . you may have a water valve that has failed . ..mm
Posted on Dec 12, 2009
MAYTAG NEPTUNE WITH NF SYMBOL
Symbol - 'Washer has tried to fill' Check water faucets & hoses for kinks. OR call Maytag 1-800-688-9900. Happy Washing!!!!
Nov 02, 2016 | Maytag Washing Machines
What does nf mean
NF = No Fill
Washing machine displays a 4E or NF Error Code
Last Update date : 2015.06.17
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
May 06, 2016 | Washing Machines
HOW TO FIX NF CODE IN MAYTAG WASHING MACHINE
Hello & Welcome to FixYa
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have an error code that says nf
NF error in your washer is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Samsung WF337AA Front Load Washer
My washer will stop and nf displays and it beeps. what does this mean?
Sorry to read about your problem, I hope this helps you out.
NF means no fill, their is a inbound water issue, water turned off, or clogged hose, etc
remove hoses and check little screens at hose ends..
if thats ok, you may have other issues in the machine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Samsung WF203ANW Front Load Washer
I am getting an error NF during the washer cycle run. The cycle will not complete and has to be restarted. What does this error message mean?
Hello
Kevin
Nov 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
It is displaying a nf and stopped working
NF means No Fill. Check inlet valve screens at the mix valve where hoses attach to machine. If there is nohumming noise at fill time, you will need to replace the inlet valve.
May 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Code nf on display
nf code is no fill ,, washer does not turn on water valves to fill washer with water ,, , chk taps is the water turned on ? check inlet screens on hoses , check wiring connections in harness leading from machine control board to pressure switch,, check water valve ... check inputs and outputs at machine control board ,,
Dec 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
What does nf mean?
NF = Not Full
Is displayed when machine does not fill with water in the allowed time. Could be low water pressure at the feed pipe. Could be dirt clogging the inlet hose screen. Could be that the faucet valve is not fully opened.
Let us know of your success!!
Oct 12, 2009 | Samsung WF337AA Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
81 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
