Question about LG WFT1071TP Top Load Washer
Cold water wont flow - LG WFT1071TP Top Load Washer
    President:
  • 1,891 Answers
Remove hoses from taps and clean sreeens . may have to both washer side and taps . if this does not work water is probably bad .. ( replace valve.) mm
Posted on Dec 12, 2009
SOURCE:
No cold water flow to washing machine
The washer could be stuck the seating .
Feb 03, 2018 | Kenmore 22422 Top Load Washer
Washer over flows wont agitate on all load sizes will spin out water runs both hot and cold water on all settings from tap cold to hot timer doe not seem to move
we have a pressure switch problem...replace pressure switch,,,i dont understand what a cold to hot timer is,,,i assume you me water temperture switch...
Sep 02, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
I installed a dhc tankless heater, but when I open only the hot water everything is ok, but when I open the cold water at the same time the heater turns off.
Hi and welcome to FixYa, I am Kelly.
What is happening is that your cold water flow is greater in volume (gals per min) than your hot water. So when you open the cold water it is mixing with the hot water inside the faucett or shower plumbing and actually reverse flowing back into the hot water heater plumbing. The reverse flow slows the water flow sensing turbine inside the heater and it is thinking that there is not any water flow. (There isn't actually due to the equalization of water pressure when you open the cold water faucett) Since this is a safety feature of the tankless heater to keep it from overheating, it shuts off.
Somewhere in the hot water plumbing there is a major restriction. It may very well be the internal plumbing of the tankless hot water heater or the flow detector design.
There are 2 ways to correct this. The easy way would be to restrict the available cold water flow. You can do this by installing another shut off valve inline with the cold water plumbing and just not open the valve all the way. You would have to adjust the setting so that the hot and cold water can be on at the same time and the hot water heater stays on. The hard way is to locate the hot water flow restriction and eliminate it.
It is possible.... if you have a flow restrictor in a shower head or a screen in a faucett areator that they are partially clogged. Clean any flow restrictors and screens then see how the hot water heater performs before you start modifying plumbing.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Stiebel Eltron DHC-E 8 Tankless Electric...
On our Model LAT9635AAE washing machine when cycle is on cold/cold the water fills at a very slow flow. If (while water flowing on cold) the water temp switch is switched to warm and back to cold the cold...
You have a bad fill (mix) solenoid valve. The valve in the solenoid is hanging up and by switching it back and fourth between hot and cold its just working its way to the proper position..You were on the right track.....
Sep 16, 2010 | Maytag Washing Machines
Cold water wont go into machine. I have replaced the intake vaulve and still wont work. Hot water will
Check the screen washer on the cold water hose. Many times these get plugged up and keep the water from flowing into the machine.. turn the valve off at the wall, and then take the hose loose from the valve.. check for cleanliness and flow. You can buy replacements at the local hardware stores..
Sep 13, 2010 | Kenmore Washing Machines
Why doesn't cold water flow into the washer through the Smartwater filter? When my Maytag Performa's Wash/Rinse temperature dial is set on Cold/cold no water flows into the tub. But when I set it on...
Hi .. I would first check the supply valve at the washer to be sure that it is open. if it is open , you can check the flow by shutting it off, removing the supply hose, opening the valve slowly and observing the flow. You might need a small bucket here. If you have water flow here at the washer supply valve, then the problem is inside the washer control.
Apr 18, 2010 | General Electric GE SmartWater Household...
Cold water flow is extremely slow. have checked
REMOVE THE COLD WATER HOSE FROM THE WASHER, AN LOOK INSIDE THE VALVE, AN CHECK THE SCREEN, FOR BLOCKAGE, SPECIALLY IF YOU HAVE HARD WATER IN YOUR AREA.,
I HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | GE Profile WPRE6100G Top Load Washer
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
No cold water flow
TRY CHANGING THE COLD WATER TAP IN THE MACHINE.
Oct 13, 2008 | Washing Machines
LG WFT1071TP Top Load Washer Logo
80 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
