Question about Amana ARGS7650SS Gas Kitchen Range
I have a matag cre9600cce, the oven heats, but very slowly and not all the way. i set it to 350 and after an hour it is only at 210
    President:
  • 1,891 Answers
The cre is elect so look for one of the elements not working / ( bake ) is probably is out . and the pre heat is only from the top element .. / test by open door ser to bake bottom element should go red / then set broil and it to should turn red . the one that does not repl .. mm
Posted on Dec 12, 2009
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 25, 2011 | Ovens
Oven is set at 350 and the temperature will not go up.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 09, 2010 | Maytag Ovens
I have a jenn air electric downdraft range. The problem is we set it for 350 and bake and it wont reach the the 350 level. It did make it to 300 but that took quite awhile.thank you for any help you can...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 08, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Doesn't get to correct temp set.
heatman101
May 05, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
Oven takes sometimes hours to get to 350. We just had the oven on for 2 hours and it only got to 210. Sometimes it will heat up right away.
it sound like your bottom element could have a crack or it is loose try screwing it in tighter and if that doesn't work take it off by unscrewing it and replace the whole heating element it is very easy to do . home depo or a appliance store should have the heating element.....
Jul 13, 2009 | Kitchen Ranges
Amana ARGS7650SS Gas Kitchen Range Logo
163 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
