Question about Standard (CRT) Televisions
TV volume control
My Dynex tv will not let me control the volume. it is stuck on the loudest it can be and when i adjust it, either by remote or on the tv itself, the numbers go down but the volume stays extremely loud. help!
5 Suggested Answers
  • 49 Answers
SOURCE: Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Posted on Feb 26, 2007
  • 52 Answers
SOURCE: quasar 33 inch tv model number sp3136k
You more than likely have a cold solder joint, and moving the tv caused the hair line joint to crack open just enough to prevent current from flowing. But before you start soldering, give it a good inspection inside for a loose connector and/or wire. If no luck, take a solder gun and lightly hit the largest joints first, which are part of the largest component on the circuit board. It has a thick red wire coming out of it that goes to the tube. (Do NOT touch this red wire or disconnect it from the tube. It can still shock you, EVEN WITH THE TV OFF. This is a very high voltage with low current and probabliy will not kill you, but it will hurt very badly, so just be careful and stay away from the big red wire coming out of the tube.) Then resolder all the larger chips, transistors, and capacitors. If still no luck, then resolder the hundreds of smaller joints.
Posted on Mar 04, 2008
SOURCE: Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
I had the same problem with the volume in digital mode and found the answer here:
The actual solution is towards the bottom of the post and hard to read through, so I simplified the instructions below:
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Posted on Jan 02, 2009
  • 668 Answers
SOURCE: i was watching tv when suddenly the volume control
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Posted on Jul 02, 2009
  • 103 Answers
SOURCE: Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Posted on Apr 06, 2010
0 characters
1 Points
Sansui platinum plus tv
Are you using a remote control or the switches on the TV?
If using a remote;
First turn the TV off at the power point then wait for 10 seconds.
Then turn the TV back on
Then attempt top adjust the volume using the manual settings on the side or bottom of your TV, if that works then you may have a remote that either needs new batteries or does not work.?
Can you turn the TV on and Off with the remote control?
Can you change channels with the remote control?
If you can do both the above it would appear that the remote is working OK.
Does this fix the problem?
Jun 30, 2014 | Standard (CRT) Televisions
Need help with magnavox TV volume control
The volume control logic circuit inside the TV [circuit board] is faulty. Contact any experienced service technician. This is not a user repairable fault.
Sep 21, 2012 | Philips Magnavox 13MT143S 13" TV
Tv is stuck on aux
Push the "menu"button on the front of the unit. That will get you into the menus to adjust any setting, like caption, language (but that one is tricky if yours happenend to be set to a language you couldn't understand :P), brightness settings and the such are there too. The one you are looking for is "input", change THAT setting. with either volume up/down +/-, or channel up/down (+) (-). In the menu, change the "input" selection to cable or whatever you are trying to watch on the tv.
Hope this helped some, if so, please rate, thank you!
Channel setup
V-Chip Setup
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.key's, will give you all the adjustments you may need without a remote control.
Feb 02, 2010 | Durabrand DWT1905 TV
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Sony 20" TV controls problem
try to disconnect your power inlet cable 110v within 5mn to make a big reset and restart your tv and reconfigure all
Mar 31, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony trinitron messed up
pressed a bunch of butons on the tv and the remote means first of all it is due to that buttons as they might be loose fron inside or broken contact. if remote & tv buttons ok check for sound section in tv. if you are not tech person get tech help it is a simple job.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Standard (CRT) Televisions Logo
85 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
