Question about Sylvania SA110 15 Amp Heavy Duty Appliance Timer
I want to buy a SA 110 15 Am Timer and need to know how it works with a slow cooker - can you set a start time and a stop time?
  • Bernie Bruns Dec 12, 2009
    I assume you plug in the timer - then plug in the cooker to the timer - yes turn on the cooker - set start and stop time . How long is connecting cable for time? Is the plug in for cooker only a 2 prong?
    Please advise
    Bernie Bruns
    Brigadier General:
  • 4,090 Answers
Yes the pin switches are gapped at 15 minutes so each one you depress will turn on the unit plugged into it. When it reaches a non depressed pin the power is turned off. so you can set it to come on ,,say 0900 by depressing the pin at the 0900 position then depress all the pins to the turn off time say 1400 ( so the last depressed pin is 1345) and then it will turn off at precisely 1400.
There are risks with mechanical switches where cooking is concerned, because they are clockwork they can fail to turn off and you risk fire.
There are digital ones that monitor power failures and are somewhat safer. My experience with slow cookers is that they have a built in timer with a delay that can be set ( Sunbeam Brand)
Thanks for using FIXYA
Posted on Dec 12, 2009
  • 15,935 Answers
Yes - just be sure the slow cooker is turned on ;)
Thanks for using FixYa!!
SOURCE:
Why is my pressure cooker not running the length of time set?
You probably need to push set again or something when it appears you should be done. I have a slow cooker and they work that way. It appears to be running but you still need to push one more button or the program will stop after 15 minutes.
Sep 21, 2014 | Cuisinart CPC-600 6 Quart Electric...
Timer to start and stop cooking
yes its great go head to walmart get those times for ac power and your good to go with safey cut off they all have
Jan 27, 2008 | Crock Pots & Slow Cookers
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
    Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    thank and thanks for using fixya.
    Aug 20, 2010 | Ovens
    The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
    hello,
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
    I'm looking for the manual for the Corningware SC-60 slow cooker. I need to know how to set the time and temperature. Thanks!
    Couldn't find a manual but here's how you can set the time and temperature: http://www.ehow.com/how_6496690_set-timer-corningware-slow-cooker.html Hope that helps.
    Jul 27, 2010 | CorningWare SC60 Slow Cooker
    Is there a timer I can purchase for the SC60?
    A timer would probably work for a slow cooker with only a switch for low, medium or high on the front of the cooker, but this slow cooker requires that after you plug it into the wall you have to tell it how you want it to cook, it won't start cooking automatically. In other words, you have to press buttons to make it cook. Hope that's clear, I know sometimes I'm not.
    Apr 10, 2010 | CorningWare SC60 Slow Cooker
    Need directions for presidents choice slow cooker
    Heat intensity is warm, 1, 2, 3 (highest)
    How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
    Apr 11, 2009 | Crock Pots & Slow Cookers
    Why won't it work?
    I had the same problem with mine. Set your timer and then hold the start/stop button until the light in your timer starts flashing, it will then start warming up.
    Oct 12, 2007 | Maximatic MST6000 Slow Cooker
    Sylvania SA110 15 Amp Heavy Duty Appliance Timer Logo
    24 people viewed this question
    Top Sylvania Hardware & Accessories Experts
    Gene Haynes
    Craig Butler
    Craig Butler
    Are you a Sylvania Hardware and Accessory Expert? Answer questions, earn points and help others
