I have a wall mounted GE 27909 DECT 6.0 Cordless Phone that works fine. I purchased a remote handset (27911) that needs to be registered to the base unit (27909). Per the instructions, I plugged in the battery to the handset and plugged in the AC adaptor to an outlet and let it charge for over the 14 hour minimum required. The light on the charging cradle shows a charge is being generated. The problem is there is no display on the handset indicating "Not Registered" as the instructions indicate. I have disconnected and reconnected the handset with the same results, no display no matter what buttons I press (even next to the base station #27909). Any help would be greatly appreciated. slott10@wowway.com
-   I have a wall mounted GE 27909 DECT 6.0 Cordless Phone that works fine. I purchased a remote handset (27911) that needs to be registered to the base unit (27909). Per the instructions, I plugged in the battery to the handset and plugged in the AC adaptor to an outlet and let it charge for over the 14 hour minimum required. The light on the charging cradle shows a charge is being generated. The problem is there is no display on the handset indicating "Not Registered" as the instructions indicate. I have disconnected and reconnected the handset with the same results, no display no matter what buttons I press (even next to the base station #27909). Any help would be greatly appreciated.
EXACTLY word for word my problem. How do I even get the back off to take the battery out?? One phone and the base phone registered fine...the other 2 won't register for the life of me....any help would be greatly appreciated. Zocon3@verizon.net-   zocon3
Apr 14, 2009
-   I bought the base and two handsets. The base and one handset set up according to directions with no problems. Both handsets were set up the same way. I can't register the second one. -   Guest
Apr 01, 2009
-   Purchased the GE Model 27909 wall mounted base and 2 additional handsets ( 27911). The base works fine, but cannot "register" the additional handsets. Followed the directions and tried several times, but no luck.
I tried to take the back of the handset off to check the battery, but cannot get it off. How do I get it off without damaging it?
Would appreciate any help.
-   Guest
Mar 14, 2009
-   My additional handset wont register either. Argh! I guess I should be relived that I'm not alone ...-   Guest
Mar 05, 2009
-   say do not disturb on LCD display but when someoen calls , no ring tone, gone thru the menu to set ring tone and volume but same thing continuously happens, plz help!!
-   mnugara76
if your ge model 27911 handset does not register with base 27909, be sure that the 27911 charger is plugged into an electrical outlet on a different circuit than the base unit. as soon AS I DID THAT, 27911 IMMEDIATELY REGISTERED WITH THE BASE. JVB CALIF.
I just bought a base with cordless and 3 additional handsets - charged the batteries, registered all the handsets and the only thing that has a dial tone is the speakerphone on the base. The cordless handset sitting on the base displays "searching.............out of range". Called the manufacturer....was told I could send the phones to them to have it looked into....I am setting up a home office and I need phones, not BS! ssheeshhh........was then told that the phones must have a defect. So much for customer service...obviously sent out for sale with known problems. Shoddy workmanship AND non existent customer service. Sending them back to Office Depot....going to stick with 5.8 because I do not know if this is a common problem with dect 6.0 or just GE models.
I had the same problem with purchase of a remote handset (27911) for 27909 phone. I tried suggestions seen on line in this order:
1. set up handset
2. unplug nearby microwave
3. unplug charger to be sure it was not on same circuit as base
4. move handset very close
5. unplug wireless router
None of the above worked after numerous attempts.
When I took battery out and then replaced it in charger after a minute, there was immediate success.
Removing the back from the handset involves pushing in the button at the bottom surface and while keeping the button pressed push the back in the opposite direction from the button. It is easier to do this by holding the unit so the button is up.
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
To register a handset to the base, apparently you must PLACE THE HANDSET WITHIN INCHES OF THE BASE (like resting on top). I experienced many failed attempts with the handset only about 18 inches away. Did anybody think of putting this into the manual?????
i have a ge 6.0 cordless phone, what it is doing is telling memory is full call back again and will...
(More)
i have a ge 6.0 cordless phone, what it is doing is telling memory is full call back again and will not go to answering machine
Handset stuck in conference call mode. Checked troubleshooting online at Uniden. No solution....
(More)
Handset stuck in conference call mode. Checked troubleshooting online at Uniden. No solution. E-mailed question to customer service at Uniden. No answer.
I just purchased a 27911 handset and tried several different ways to get it registered to the base...nothing has worked. First I followed the manual directions (multiple times). Then I tried unplugging the base and tried again. Then I unplugged the base with the new handset in the cradle, still nothing.
Comment by Guest, posted on Dec 26, 2008
Went through all the "registration" steps but after pressing the "Page" button on the base the handset did not register!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
