Question about GE Refrigerators
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
    Scholar:
  • 49 Answers
On most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Posted on Dec 12, 2009
No power to the compressor
The thermostat circuit is responsible for sending power to the compressor for normal operation. Make sure that the thermostat is working and not stuck on open position.
Aug 15, 2014 | GE G.E. Profile Bottom Freezer 25.5 Cubic...
Why does my GE Arctica Side by Side refrigerator make groaning noise?
All new refrigeratos make some sort of groaning noise and this noise is heared at diffrent times of the day. This noise you are hearing is what we call refrigerant noise. As the liquid frigerant is moved through the system it gets to a point were it will enter the capillary tube at this point the frigerant flashes in to a gas (changes from a liquid to a gas) when this happens it tends to make moaning and groaning noises. There is no real fix for this noise.
May 02, 2012 | GE Refrigerators
I HAVEA GE SIDE BY SIDE, THE FRIDGE AND THE FREEZER ARE ONLY COLD IN THE BOTTOM HALF, FROST BUILD UP IN THE FREEZER, BOTTOM HALF,
HI you have a bad defrost heater, located in the freezer behind the rear panel at the bottom, the part cost around $50-70.00.
Sean
Mar 28, 2011 | GE Refrigerators
Leak under freezer portion
Check out these tips...they can help you figure out what is going wrong with your refrigerato
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Freezer ice cold but refrigeratoer side warm
Must adjust the food compartment settings to a higher level. If that does'nt do it in 24 hours .You have a faulty evaporator fan....The evap.fan distributes cold air from freezer to food compartment...Jack Arevian
Jan 24, 2010 | Frigidaire FRS26H5AS Side by Side...
My ge refrigerator leaks water
During defrost cycle, the water produced is suppose to drain away through a small drain hole located behind the racks in the freezer section where you'll need to remove the rear panel to see the drain hole. This hole it very likely clogged.
Be careful to unplug the refrigerator before doing any work on it!
May 29, 2009 | Whirlpool GD2SHGX Refrigerator
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water or ice
sounds like your door swith is not working. it wont let water or ice flow when door is open (even when door is closed it is not making contact)
Jan 12, 2009 | Refrigerators
Refrigerators Logo
202 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Brian Coughlan
