Question about Dell Dimension 9200 PC Desktop
When i switch on there is a buzzing noise and
When i switch on there is a buzzing noise for a few seconds and machine wont start . Screen appears to be in power save mode??????
  • 488 Answers
Sounds like an issue in your power supply. Try a good second hand supply or, if you have to purchase a new one, get a new case with a supply and install the guts of your PC into that as Dell power supplies are very expensive (if they are available at all for your model). Swapping everything into a new case is a pain I know but it may be a lot cheaper then a dell supply. You can also have your supply tested by a professional. Don't be tempted to open the supply and fix it your self.. Switchmode supplies are more then happy to provide all the power needed to turn you into a sticky mass on the floor!!! and the surge capacitors can hold a formidable charge for several hours which really stings when it bites you !!!
Posted on Dec 12, 2009
Kyocera machine displace C6000 call service
enter the service mode by pressing 10871087 .there will be U000 then press 163 through keypad then press START button 4 times machine will restart .wola. check ur input voltage it is fluctuating
Jun 02, 2011 | Kyocera KM-1510 Copier
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
May 18, 2011 | Maytag Bravos MTW6600T Top Load Washer
When hitting start button, it sometimes buzzes, but fails to start. Can sometimes wait for a little while and try again, and it starts. When it buzzes, it will only buzz for a few seconds and then nothing.
it is either the door switch or start switch, this website will show you how to test both, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 16, 2011 | Whirlpool LER4634J Electric Dryer
Bugera 333xl every few seconds there is a loud buzzing. from
It looks as though you have ripple noise that amplifies into the output. First of all check if the mains voltage is going down to produce the low voltage hum. If not you will have to check the DC filter capacitors , couple in parallel to confirm the capacitor. IF the buzz is still coming through then you will have to isolate the preamp and wait it the fault is coming in. If not connect the preamp output to another amp to hear the same buzz to confirm the preamp to be faulty. If so you will have to trace by a voltage check when the buzz occurs to confirm if the preamp IC or the selector Ic is faulty. Some logic IC's can also produce this noise on static switching. If teh noise is appearing on both the channels, then I would still bet on the power section. So check once again on the rectifier/ regulators and capacitors. Hope this advice helps. Good day
May 16, 2010 | Audio Players & Recorders
Car wont turn on smells like gas
It should not smell like gas unless the engine is REALLY flooded. But todays computer controlled cars won't allow that. I think you have a fuel leak somewhere.
Mar 25, 2010 | 2004 Nissan Altima
LE40556P lcd samsung. Screen will not switch on.
usually you can see the tops of one or more capacitors bulged up when the power supply board has failed. VERY common on Samsungs.
Nov 18, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
2001 ducati 750ss wont start
does it start and run when you jump start it? if so, you probable need a higher cranking battery. sounds like the battery isnt powerfull enough.
May 20, 2009 | 2001 Ducati 750 SS i.e. N-C
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Dell Dimension 9200 PC Desktop Logo
333 people viewed this question
Alun Cox
