Question about Sony Ericsson K320i Cellular Phone
Keys light on all the time
Keys are always lightening, this cause battery to quick discharge .
    Brigadier General:
  • 7,752 Answers
You will need to take the phone and have the mainboard check or replaced.
Posted on Oct 15, 2008
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
My 2010 jeep wrangler unlimited sport won't shift
check battery, does engine start.
do the head lights work keys in pocket?
battery voltage is 12.6v, rested, is it? key off.? all things off.
wiper run key off? or on?
park lock out, is a whole other matter.
1st is battery , always. 1st, (they can discharge)
Sep 21, 2014 | 2010 Jeep Wrangler
After using quick my Ford Exploere 2004 car wont start anti thft light blinking
The battery reset protocol usually means the 8 turns routine using the original keys with key fob transponders
Turning the key and moving the shift from park to drive and back again has helped some people
More information here
https://www.cargurus.com/Cars/Discussion-c112_ds558688
Aug 16, 2017 | Ford Explorer Cars & Trucks
Display is faint and to light to read
Turn the calculator on. Hold down the "C" key (just above the ON key) and press + to darken the screen. If you go too far, use the C and - keys to lighten the screen.
Jan 21, 2012 | HP 10b Calculator
The i on my keyboard won't work all the time I have to hit it hard. Debbie
hi there...
Looks like your keyboard have some problems with Dust.
Jammed keys are more caused by getting dusts and other small particles into the keys.
1. Best way of get rid of jammed keys is clean the surface. you can use a small vacuum cleaner for this.
2. Another way is not permanent solution, yet it will give quick results. turn the keyboard back side up. give one or two light slaps on the back of Keyboard. shocks caused by the slaps will move jammed keys. but this is a temporary solution.
Mar 13, 2011 | Computers & Internet
I am a teacher. I have about 10 calculators that
It has two batteries CR2032. They should not be removed at the same time. There must always be one battery in the calculator. The calculator should be turned OFF when changing batteries.
Often after you change batteries the screen contrast may be too light and you cannot see anything. The contrast can be adjusted (lightened or darkened). As you adjust the contrast setting,a highlighted number in the upper right corner changes to indicate the current contrast setting; 0 is the lightest, and 9 is the darkest.
To adjust the display contrast:
1. Press and release the [2nd] key.
2. Use one of two keys: (UpArrow or DownArrow)
--- To increase the contrast (darken), press and hold [UpArrow]
---To decrease the contrast (lighten), press and hold DownArrow
Hope it helps.
Thank you for using FixYa.
Nov 23, 2009 | Texas Instruments TI-80 Calculator
Keep copier ready; disable powersave option
This is going to be a user program:
1) press and hold both light and dark keys
a) the 2 buttons to lighten and darken copies
b) hold both for 5 sec until indicators light up
2) use the left copy quantity key show 2
3) press your copy key
4) use the right quantity key to change to 2 (max 90 sec)
5) press the copy key
repeat step 2 but change to 3 with left quantity key
press the copy key
change right number to (4 = 60 min, 1 is default at 5 min) then press your copy key.
Once done press both light and dark key again to exit
Note*** changing shut off timer and preheat will effect copy lamp ready state. Every 60 sec or so the scanner will move and reset. Some people do not like the noise is makes all the time. If you don't you can always change it back to the defaults. 2=0 and 3=1.
Oct 12, 2009 | Sharp AL 1631 Copier
Dischargeing battery when not in use
Hi,there have to be something runing at all times,check if the brake light is not staying on or the trunk or hood light,radio ,amp ,ect....
Jan 04, 2009 | 1995 BMW 5 Series
Battery gets discharged
Possible Problems:
1. Maybe there's a virus.
2. Often restart can drain the battery.
Possible Solution:
Format it by pressing the green key or call key + no. 3 + asterisk(*) at the same time. But 1stly, turn off ur fone, then b4 the NOKIA logo appears, hold these following keys altogether. You will see the "Formatting" word afterwards..
OR...
Format it by typing *#7370.
Aug 03, 2008 | Nokia 3230 Cellular Phone
Keyboard problem
it's the same for me, but i figured out the problem came from the earphone jack, when i plug in to my television the electric spark caused that line of keys to stop functioning like normal, but after I discharge the jack with an ordinary headphone for a while, the keys back as normal
Sep 12, 2005 | HP Jornada 720 Pocket PC
Sony Ericsson K320i Cellular Phone Logo
16 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
