What would cause my flat screen tv to turn off and on by itself??
Wat can cause my tv to turn of and on bt it self am gettin sick now...help please
Posted on Feb 01, 2010
SOURCE: my GVA LCD flat screen TV switches itself off as
My flat screen will not turn on the green light flashes for a while then stops
Posted on Mar 03, 2010
keiffertech
  • 96 Answers
SOURCE: TV TURNS OFF
This could be a loose wire internally, also some have a heat saftey switch if the tv gets too hot it turns off, I would recommend bring it in to a tech.
Posted on Sep 03, 2009
SOURCE: Philips flat screen TV MODEL ID 19PFL5422D/27
I bought the television less than a year ago, so I called Philips Magnavox and they asked for the serial and model numbers. Next thing I know they asked for my name and address and Philips is sending a brand new television to replace it !!! The new one should arrive in about ten days. How's that for service? I'm very happy that I bought Philips and I will do so again. So don't forget to keep all the paper work that comes with your new televisions,especially Model and Serial numbers ! Thanks for asking , Debbie Hoffman
Posted on Aug 19, 2008
dsacco86
  • 1077 Answers
SOURCE: Flashing red light on front of Sony Wega flat screen tv
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 16, 2009
  • 608 Answers
SOURCE: akai flat screen lcd tv.. turns itself off after about 10 min
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Posted on Dec 10, 2010
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
RCA flat screen TV turns off by itself and won't turn back on
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | RCA L22HD41 22 LCD TV
I have a vizio e320va that when turned on the backlight flickers repeatedly with picture in and out then starts blinking with vertical lines then the screen goes black and the power stays on, This is all...
The tv is having a problems with the board called T-Con board it is dying and the problems.That why the tv is not sustancening the tv pictures for those coded pictures pixels by the T-Con board to stay on to the tv LCD screen panel.This tv problems only causes by the tv T-Con board it is dying only if the tv problems came on to the tv by itself only.If these problems causes by u or an object by outer forces by hitting to the tv LCD screen panel itself.Now the tv LCD screen panel itself it is dying and the causes.Than the tv it is not repairable,tv now only can it to do a replacement of the tv whole LCD screen panel itself only.Not practical because the tv LCD screen panel are 90% important to the tv and the cost of the tv.If u replacing the tv LCD screen panel itself will cost the same as a new tv.The tv is under a year old,why don't u just call Vizio corp. and take ur tv warrenty repair.
Sep 26, 2011 | Vizio E320VA 32 in. LCD HDTV
Problem with the LG 42PC3D 42 in. Plasma Television Horizontal half black screen, sound is still there
Sorry this tv it is not repairable because the tv Plasma screen panel itself it is the tv problems and the causes,this tv only can be repair by replace the whole new tv Plasma screen panel itself only not practical.Because the tv Plasma screen panel are 90% inportant to the tv functions and the cost of the tv.By replacing the tv Plasma screen panel will cost the same as a new tv.
Sep 22, 2011 | LG 42PC3D 42 in. Plasma Television
Blue line down right side
The blue line came on to the tv LCD screen panel by itself,not caues by u or an object by hitting the tv LCD screen panel itself wright,if yes this problems can't be repair because the LCD screen panel itself dead.Blue line happen by itself,the tv board that call the T-CON board it is dying and the causes.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacemrnt.
Jun 22, 2011 | Polaroid TLX-01511C LCD TV
I have a Samsung LN46B530 LCD TV. There are 2 parellel lines on my screen, tv is 2 years old, first started with 1 thin line in the center of the screen, now that one has gotten thicker, and another one...
These lines came on to the tv LCD screen panel by itself?Yes,than the board that call the T-CON board it is dying to causes this problems,if these black lines problems causes by u or an object by hitting it to the tv LCD screen panel itself,it can't be repair,the tv LCD screen panel itself it is dead and leaking radiations.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jun 22, 2011 | Samsung LN46B530 LCD TV
I have a large spot on the right side of the LCD screen, it looks like a large water spot does it mean the VIZIO TV is going out? What can I do to make it disappear.
Not possible.Tv have damages to it LCD screen panel by an object or a person have causes by forced or putting pressure to the tv LCD screen panel itself to causing colors picture pixels and it radiation to died to causing this problems.Sorry it time to buy a new tv,because by replacing the tv LCD screen panel itself will cost u the same as a new tv.Tries buy a new tv from the VIZIO tv corporation directly return the damages LCD panel tv to them,u could get a 5 or 10% off of the tv prices.
Jun 05, 2011 | Vizio VU42L 42 in. LCD TV
My tv turns on but it shows colored verticals lines all over the screen then turns off
If this problems,the tv is causing this by itself,not by somebody or something hitting the LCD screen panel by causing the damaging the LCD screen panel itself.If this problems is causing by the tv itself,the T-CON decoder board is dead.This T-CON decoder board sit wright at the middle bottom of the tv LCD screen panel.Replace this T-CON decoder will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
Nov 12, 2010 | Sylvania LC260SS8 26 in. LCD Television
My GVA LCD flat screen TV switches itself off as
Feb 23, 2010 | Televison & Video
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
