Question about Maytag PAV2300 Top Load Washer
Washer was filling but not aggitating,
Maytag performa washer was filling but not aggitating, my husband forced it to move and it washed that load and one more. Now it is jammed and we took the shaft cap off and the nut but can't pull out the aggitator. I think something may be wrapped around the underneath. What tool does a repairman use to take the aggitator out? What do you suggest we try next.
    President:
  • 1,891 Answers
Remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
Posted on Dec 12, 2009
Water coming from bottom white round piece of washer during aggitation
Could you please describe the problem you are having a little better?
Nov 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Washing machine
Most Maytag washers have 2 belts - looks like the drive belt is not good anymore and needs to be replaced.
Aug 18, 2009 | Maytag Performa LAT2500A
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
Water problem
Apr 01, 2009 | Washing Machines
Have a ge washer, filss then does not progress to
May be a bad water level switch.
Open the control panel, with a full tub of water bump the water level switch with your hand. If it starts to agitate, replace the water level switch.
Mar 20, 2009 | Maytag Performa PAV2200
Maytag performa pav2300
Just rehook the clear tube back onto the air dome (back right side of drum), drain any water from the drum, the refill, pressure switch will reset itself. Start to fill on small load size first, then move up when washer starts to be sure it reset all the sizes.
Aug 06, 2008 | Maytag Performa PAV2200
Agitator stopped moving back and forth
dismantle the agitator and see if the shaft of the gearbox is moving.its either the gearbox or the agitator
Feb 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
271 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
