Question about Whirlpool ET8CHEXSQ Dryer
Dryer makes loud sound while running sounds like a bearing
Dryer when running makes a very loud sound.
    President:
  • 1,891 Answers
A lot fo things cause noisey dryer . ( look for wire clothing stays in drum/ pins in the felts back and front. or dad may have left a sheet rock screw in his pocket . or a key / these things we take out of dryers every day . look hard . i think you will find some thing .. slow sounding noises are related to the drum . fast and hi pitched noise repate to motor and drive componet's .. mm
Posted on Dec 12, 2009
2 Suggested Answers
  • 210 Answers
SOURCE: squeaky dryer
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
Posted on Jun 03, 2008
My frigidaire fer231cas2 makes a horrible loud noise after its been running for 10 or so mins
There are rollers that the drum sits on. The roller surface or bearing can go bad causing the noise.
Aug 26, 2014 | Frigidaire Dryers
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Feb 16, 2013 | Dryers
I have a rubbing sound each time the drum turns in my Maytag Neptune dryer
Run the dryer empty, if you still hear the sound but not as loud as when loaded, the bearing to the drum are shot. Either way, I think the bearings are bad. They are permanently lubricated, so ther is no greasing them.
Dec 24, 2009 | Dryers
Drum on dryer makes loud noise when running - sounds like a clicking/banging noise? Model LDG8424ABE
sounds like some thing went through the drum or the bearing is worn out
Aug 29, 2009 | Dryers
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
My dryer is making a loud noise
The wheels on each side at the bottom that support the drum are worn and that is causing the drum to bounce and make the noise.
Apr 12, 2009 | Whirlpool LGR7646E Dryer
Loud noise when dryer runs
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Sep 27, 2008 | Dryers
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Whirlpool ET8CHEXSQ Dryer Logo
275 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
