Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
We can't not get the manual to work as well as the automatic neither will release
  • marty metzger May 11, 2010
    Have no idea what you are saying?
    President:
  • 3,197 Answers
Pull the rope straight down and then back toward the motor to release.
Posted on Dec 15, 2009
I have a E-ZGo -2five SUV and the automatic emergency brake has locked up. How do you unlock it. Jerome
try rocking it back ,and fourth .That may release it does it release when you put it in gear normally, or do you release it manually? If manual, look for springs that pull cable back when you release it, if it releases when put into gear look where lever releases cable. If unit has sat for awhile rust may have frozen brake parts...rocking may release it.
May 14, 2017 | Cars & Trucks
Automatic fuel door release will not function, how do I use the tool called "Fuel Door Release Manual Override"? Also how do I go about fixing the automatic release?
SHOULD BE A THIN CABLE ON THE SAME SIDE AS THE FILLER DOOR IS,IF ITS MISSING ALL YOU HAVE TO DO GET TO THE INSIDE OF THE FENDER WELL AND LOCATE THE RELEASE LEVER.
HOPE THIS HELPS
Oct 21, 2010 | 1991 Buick Riviera
When starting the engine, the engine turns until comression then stops. If I manually turn the engine back it does the same for several attempts and eventually starts.
Your compression release is not working as it should. On some saws, the compression release is a manual lever / button that is pressed before starting attempts. Sometimes it is tied into the choke. Other saws have an automatic compression release, based on a centrifugal cam.
If you are able to rotate the engine through the compression cycle, then the release "lobe" is likley worn. If you are not able to rotate the engine through the compression cycle, then the release mechanism is jamming.
Sep 09, 2010 | Garden
My honda accord 2003 automatic wont let me put gear shift from Park To drive. I cant press de button to make it get to drive
Sounds like your brake interlock is not working. You can manually override it. Check your owners manual, but there should be a small square around the trim around the shifter. Pry up the square and there is a release mechanism to manually release the solenoid. It should be covered in your owners manual how to override it.
I think to replace it you need to take apart the shifter trim.
Sep 04, 2010 | 2003 Honda Accord
On a 2007 Harley FXSTC 110ci my compression droped after fresh rebuild. the way it acted was that it was hard to start up until it seemed like it shot a punch of air out of the airbreather. I believe its...
Automatic compressin releases are connected to the starter circuit. As long as you hold the starter button down the compression releases will be open. Check the push rod adjustment if they are too tight it will cause the symptoms your discribing.
Apr 14, 2010 | Harley Davidson FXSTB Night Train...
If the automatic trunk release does not work. Is there a manual or a key entry for trunk
There should be a manual release accessed thru the back seat,Check your owners manual.
Jan 11, 2010 | 2005 Pontiac Grand Prix
I can't get my convertible top to go up or down, it is stuck half way. Is there a manual release for it?
The convertible top motor and release lever are in the luggage compartment.
From the Bentley manual, the following general procedure is suggested in order to close the top in an emergency situation.
Main motor. To release the top linkage from the motor, lift the left corner of the rear seat to access emergency release handle.
It is then possible to push the top manually to a near closed position. In case of the semi-automatic top, simply attach and lock the front latches.
Front latches. Once the fully automatic convertible top has been released from the motor and manually pushed to near-closure, emergency latching of the top is possible by using the S-shaped hex key provided in the emergency tool kit(attached to the trunk lid underside).
First, remove the the plastic cover over the latch motor in the front bow of the convertible top.
Next, use the hex key from the tool box to crank the front latches shut.
May 12, 2009 | 1999 BMW 323 Series
Automatic gearshift stuck in park
The release for the shifter is tied to the brake lites, check to see if the brake lights work, if they don't then test the brake light switch at the top of the brake pedal, if it lights a test lite when you press the brake it is ok, in that case you need to check the little solenoid that pulls the cable to unlock the shifter, it is bolted to the top of the steering column, in order to get at it you will have to unbolt the column and drop it dow.
Oct 09, 2008 | 2001 Ford Focus
The flash unit for my D50 doesn't pop up automatically
The flash is spring-loaded and always "trying" to spring up. It is held down by a small lever that should disengage automatically when the flash is instructed to pop up either manually or in automatic mode. It sounds like the small lever has broken on the inside and will not release. The camera must be opened in order to repair this, and this should only be done by a qualified technician.
Mar 03, 2008 | Nikon D50 Digital Camera
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
37 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
