Question about Maytag Neptune MAH5500B Front Load Washer
Front load MAH5500BWQ filled up, door locked and didn't start up. clicking sound heard. Tried to get service code - gave me code 17
  • 1 more comment
  • soboczynski Dec 12, 2009
    I've got a service manual - that is how I got code. Not sure how to perform lock test.
    I cleared the codes and am no longer getting that code 17 and the machine is doing the same thing.
    Fills up, door lock and it just sits there. it is clicking, trying to move on to next stip.
    I gave insufficent information in my original question.
    I do have a Maytag service manual but it has limited troubleshooting info. It goes by codes and the only code it gave the firt time I ran diagnostic was a code 17, which is listed as door lock. I erased codes and attempted to start machine and same thing happened. Filled with water, the door locked and it started clicking. If allowed to sit the timer counts down even though nothing is happining. The door is locking.
    The machine is LED readout, not the digital.
    still rec'd code 17, could be that latch
  • 10,515 Answers
Unplug the Washer for Few Minutes and Then Turn it Back ON.If you are getting same Service Error Code, you might need to Replace the Door Latch Assembly and you could get it at Appliance Parts Dealer or Online at www3.sears.com.
On Most Models, to replace it you will need to open the door and remove the screws from the hinges into the cabinet and the ones across and then pop the front panel off, open the dispenser and remove the screws, take the two screws out holding the top down and raise / swap the latch assembly and put back together.
Also Check the Wires on Door Switch and Latch Assembly.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
  • 15,935 Answers
Diagnostic code 17 means the lid was not opened after completed wash cycles.
Complete the LID LOCK TEST.
Maytag neptune front load washer mah5500bwq ran a service cycle got these codes d 15 and 17 15. 17. What's this mean
Since repairing washers is a hobby and not a profession, I'm not familiar with that particular washer. I know that those codes usually mean it overfilled (D15) and the door lock failed to properly engage.
If you know what you are doing, you can check the switches with an ohm meter. Please don't do this if you aren't sure how to do this safely.
May 18, 2014 | Washing Machines
Door wont lock will not close properly
Cut and paste this factory service manual.
It will show how to access,test and replace all components.
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Jul 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
I am getting the code on my frontload washer F du, it is making a clicking sound the water starts to fill , then the code comes up..I am not able to find this code in my manual ..I am thinking that maybe...
The DU in the display is an error code for the door lid not unlocking. This is an indication that the lid lock assembly has failed or the control board is unable to determine if the lid is unlocked. This usually indicates that the lid lock assembly will need to be replaced.
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Service manual above.
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
I have front loading Maytag Neptune. Can't get door to unlock. Cycle started, but door wasn't closed properly, signaled "do" and when I tried to open door, it was locked and won't unlock. Have tried...
After getting no response from FixYa, because it told me that my session had ended, and I hadn't even started, I called a local repairman! I had better not be charged for your service, as you site is faulty and gave me no assistance or info, just seemingly took my money.
Jun 29, 2009 | Maytag MAH6700AWW Neptune Front-Load...
F dL code message
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replace the door lock mechanism asap. this will fix the issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
The control locked light is on and can't start the machine
Power shd be on, try to hold down 'end of cycle' button for 3 seconds, try door after a minute or after hearing a click. IF NOT:
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Apr 06, 2009 | Kenmore Elite 45986 Front Load Washer
Try to start light flashing ld and f what does it mean
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Error codes
f dl refers to a bad door lock. do you hear a faint clicking noise when you try start the machine and after maybe 30 secs of clicking the" fdl "comes up???or perhaps the door makes the noise to lock but never does lock,in which case sounds like a bad latch assy.. although the fault for the door latch it could also be the CCU not energizing the door lock. try taking off the top of the unit by removing the 3 screws along the back of the top assy (they are torx 20 screws) form there youll see the main control board mounted to rear wall and if you look straight down the right front side youll see the wiring for the door lock itself. disconnect power to unit!!!!! first unplug and replug all the wire harness on the door latch and then also the pink wires on the module itself, maybe just a loose connection. try it now see what happens
Mar 17, 2008 | Whirlpool GHW9100L Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
