I have a minisplit unit that leaks out the freon
I have a minisplit model #aos121hx outdoor unit & aws121hx indoor unit it throws a code p8 which is low freon or conversion valve, recharged unit it worked for one day and threw the code again, i tightend all fittings before recharging and it still leaked out. i used sniffer and it beeps around the outdoor unit where the valve exits unit, what can i do?
  • 767 Answers
Try leak stop that they sell for refrigeration and air conditioning systems
Posted on Dec 12, 2009
SOURCE:
How to check MSG12HRN1W MINI SPLIT SYSTEM electronic board
If your mini split was installed to meet most building codes, an inside disconnect switch should have been installed. This switch breaks the power and signal from the outdoor unit to the indoor unit. It is not the same as the outside disconnect to the compressor (outdoor unit). If it was turned off, the inside unit would be dead. Look for a disconnect switch inside your room. By code is should be within 15 feet of the inside unit.
Nov 04, 2014 | Heating & Cooling
I have a LG minisplit (indoor unit LSN122HE /outdoor unit is LSU122HE) it cools great dehumidifies also and has for 3 months of summer. However its cold now and it will not heat. It runs for a min out
That's an inverter series motors... the outdoor fan motor is on an ambient controller to maintain pressures when cold outside in air conditioning mode, but not in heat...only defrost when needed. Check the settings on the outdoor board for defrost timing
Dec 02, 2013 | LG LSN122HE / LSU122HE - 11,500 BTU 13...
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
We have a P8? CAN'T FIND MANAUL
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi electric Mr Slimair conditioning. It runs a few minutes in cool mode, then it stops and an error of P8 code appears. When it runs, the fan is not strong.
connecting wire
2) Reversed phase
Solution:
Hope,it's helpful.
Jan 15, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
My mr slim is not blowing cold air, just warm, and a message P8 is flashing
P8 means "Abnormality in Outdoor Unit"
Possible causes
1 Wrong wiring of Indoor/Outdoor connection
2 Reverse Phase
3 Protection Device operated
4 damaged Outdoor coil thermistor
Aug 05, 2009 | Mitsubishi Heating & Cooling
Error code F1 displayed on unit
We had the exact problem with our unit at work. What we did was turned the unit off at the panel and grounded L1A (or B depending on which fan is displaying the error code) at the condenser and then verified that L1 was grounded at the air handler. In our case it was not, so we rolled L1A and L2S at the condenser. This fixed the error code on our units. Evidently the units need the same sequencing on the fans that the condenser has.
Jun 25, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
