Question about DeLonghi DC312T 14-Cup Coffee Maker
We just received this coffee maker but without instructions. there is a plastic long piece with two oval holes in it. where does this part go and is the bottom of it supposed to hold a filter?
Get the manual here: http://www.delonghiusa.com/index.php?product&nid=94
Posted on Feb 06, 2010
This is the chlorine filter holder. Need to buy the chlorine filters. Not cheap.
Posted on Jan 04, 2010
After turn on the machine display group blocked
The flap of the funnel has a piece of plastic that sticks out, which pushes on a microswitch under the top cover.. If the funnel is not seated correctly, it will not work the microswitch.. This will also apply if you try to use it with ground coffee.
There are 2 switches side by side, the other is for the bean hopper cover.
I suppose you could insert a small stick into the hole, and press towards the front of the machine.. it should have a distinctive click to it. if it works, then either the plastic piece on the ground coffee cover is broken, or the funnel is not seated correctly.. if it doesnt work, you need a new switch fitting.
Aug 05, 2013 | Saeco Vienna Digital Coffee Maker,...
Cleaning cycle
Jun 30, 2013 | Jura Capresso Impressa Z5 Espresso/Coffee...
Take it apart
To make a tool to remove the oval screws. Take a 3 inch hinge pin and use a 9/64 inch drill bit. Drill a hole in the bottom of the hinge pin about 1/8 inch deep. Make sure this fits over the oval screws. Take the hinge pin with the hole in the bottom and squeeze it together in a vice.
squeeze it a fraction until it will lock onto the oval screws. Use a vice grip plyers to hold the tool as you turn it, It worked for me. Bobby Rice
Dec 08, 2012 | Nespresso D290 Espresso Machine
Reassembly instructions
That little screen that lies at the bottom of the bucket needs to be snapped out and the washer replaced. You have to unscrew the bottom, carefully remove the spring loaded lever, ( don't loose the spring) After fishing the lost rubber washer out of the hole, I used a screw driver or other similar item to pop the screen out. ( use care not to poke a hole in screen.) Next replace lever and spring and push the Star ended piece through the bottom and THEN fasten the washer. Replace all excess pieces and it should be fixed provided the washer isn't badly worn. This is the only way I know how to fix it after countless different web pages and searches.
Apr 08, 2010 | Hamilton Beach BrewStation 47665
Coffee very weak, some grounds are still dry after coffee is made
I2 have same. Problem = not a nozzle missing, but a black plastic diffuser mounted below the orifice. Plastic becomes brittle and disintegrates within weeks. Pieces fall into grounds so you may never notice. Photo is of pieces I recovered from the grounds. Horribly bad bit of engineering on an otherwise great product. (Saved how much over cost of stamped stainless?) I have not been able to find replacement part, although OEM piece would fail again within weeks. ALL ProLine makers MUST fail in the same way - the plastic part CANNOT survive actual use. KitchenAid should offer steel replacement! ad74f59.jpg
Feb 28, 2010 | KitchenAid Pro Line Coffeemaker Coffee...
I have a Delongli EC330S and has reduced it coffee flow to a very slow drip, pump sounds ok, can't see any pipe blockages,I need help
I think I have solved this problem quite simply by buying a new pack of Expresso coffee, it seems that I must have ground the coffee beans I had too finely if that is possible, But it does seem to be working ok now
thanks
Nov 15, 2009 | DeLonghi DCM485 Coffee Maker
The plastic top of the glass pot on two coffee makers drip.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
Apr 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DGB coffee maker
there is two little plastic pieces sticking out of the bean holder and on the coffee maker where the bean holder goes there is 2 holes, take the bean holder and put one piece of plastic in the coffee maker holes at a time and it should fit just fine...
Sep 13, 2008 | Cuisinart DGB-600 Coffee Maker
ESTRO VAPORE
I just took mine apart, and put it back together. Of the three holes for the screws, there are two smaller and one bigger hole. Align the larger hole on the filter and the base, and the tiny plastic bit and the spring go in to the larger, along with the hollow and larger screw.
Aug 11, 2008 | Estro Barista Athena
DeLonghi DC312T 14-Cup Coffee Maker Logo
226 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
